Fuel Pump
Sep 14, 2006 | 01:29 PM
Fuel Pump
Currently putting in a escort rs turbo engine into a mk5 escort xr3i would I get away with using the mk5 fuel pump?
Thanks.
Sep 14, 2006 | 03:43 PM
If you're still using the KE-jetronic, then probably no.
Sep 14, 2006 | 04:05 PM
Quote:
Originally Posted by JesseT
KE-jetronic
Sep 14, 2006 | 04:11 PM
Depends on what system your car currently has. MFI or EFI and it will be fine, single point injection pump might not be up to it.
Sep 14, 2006 | 04:19 PM
Well RST lump is running MFI but engine that was in car was running EFI if that helps?
Not sure when it comes to fuel side of things on rs turbos
Sep 18, 2006 | 01:19 AM
BTTT
Still need help on this.. Car is about done now
Sep 18, 2006 | 01:14 PM
u will need the rs turbo fuel pump as mfi requires around 5-6 bar of pressure. the efi pump u have will be well below that
i put a s2 turbo in my mk6 and had to modify my fuel tank to fit the rst pump
Sep 18, 2006 | 06:28 PM
If its running EFi can't you use the Fiesta RST in tank pump or the Escort Cosworth one?
Dave
Sep 18, 2006 | 07:51 PM
If you use EFI Turbo any EFI fuel pump will be fine.
If you use KE-Jet you will need a KE-Jet pump! And you won't get them as in-tank!
Sep 18, 2006 | 08:27 PM
just put an fiesta turbo one in it as its in the tank
not out side as an erst
Sep 18, 2006 | 08:43 PM
I think you'll find the standard pump will probably get the engine running but its not going to be up the job of high end fuelling.
As suggested it will be easiest to fit an FRST pump, straight swap i believe
Sep 18, 2006 | 10:56 PM
Thanks
SafeChav
So a FRST pump will be the one then
Wont have to change fuel line's ect then?
Sep 19, 2006 | 09:56 AM
No all the injection cars have the same size fuel lines etc.
Its the flow rate and delivery pressure of the pump thats important.
Sep 21, 2006 | 11:10 AM
as said above, the mfi system requires alot more pressure than the efi pump will give
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 27, 2015 04:55 AM
155lee
Oct 24, 2015 11:11 AM
wheelwizardrefurbs
Sep 23, 2015 09:21 PM
tib2220
Sep 14, 2015 12:33 PM
