INTERIOR/DASH PICS REQUEST
Hey up, i've got some gauges i want to put in my dash and i'm after some inspiration as to where to put them. i.e. centre vents, dash top, instrument surround, pillar etc so if you could post some pics (or links to pics) that'd be great.
Col.
Col.
Hi guys,
i see some of u have replaced your coin tray with a pair of gauges, did u fabricate them your selves or buy them.If so where from? They look cool as Feck!
Twins The picture for the steering column pods also shows the two guages in the clock surround,on the right handside!Do u supply these? As i know u make the other surrounds etc? Also a price please!
Take a look at Tony Turbo's RST dash set up. He has a Stack for the rev counter and digital speedo and the whole range of Defi gauges and is the best set up i have seen in a S2
(and dam expensive too
He has the defi controller that controls gauges for: Water temp, Oil temp, Oil pressure, exhaust gas temp, Fuel pressure and Turbo boost pressure. He also got An Autometer fuel gauge and boost controller below the radio and had the Dash flocked and matching interior trims matching flocked
Its EAXTLY how i would do my RST if i had the money
) He has the defi controller that controls gauges for: Water temp, Oil temp, Oil pressure, exhaust gas temp, Fuel pressure and Turbo boost pressure. He also got An Autometer fuel gauge and boost controller below the radio and had the Dash flocked and matching interior trims matching flocked
Originally Posted by Black_RS
dave_y - what make are your gauges?
I've got ideas now but need more - I'll be tackling the job myself and keeping you all updated in the rebuild thread...
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
[/img]
