maf senser
hello all, iv just found that when i disconect the maf sencer from my evo it ticks alot smoother ? i take it that its unsafe not to run with the maf out ?
im just fiting a new idle control valve as these or always going on the early evo, s .. so until i fit the ICV i wont now what it will tick like, iv taken off the after market dump and got the recircled one back in place just how mitsu ment it to be
andy
andy
With the MAF sensor electrical connector disconnected the ECU will apply a defualt value for MAF which will run the fuelling rich to save any further damage so you may even get slightly better perofrmance but worse fuel consumption!!
HTH
Andy
HTH
Andy
ASHCOSSIE
Oct 26, 2005 07:52 PM
and ticks ok now , common problem on all evo,s
