NGK BCR8ES
Old Sep 13, 2006 | 08:38 AM
T28 RST's Avatar
T28 RST
Ok then
Default NGK BCR8ES
What gap should these be set at, the car is running 16 psi boost if that helps
Old Sep 13, 2006 | 09:29 AM
davsmith64's Avatar
davsmith64
0.8mm on the bcr8es davie.
Old Sep 13, 2006 | 10:42 AM
T28 RST's Avatar
T28 RST
Ok then
Cheers Cowell
What is 0.8mm in thou, was told 26 - 27 thou
Old Sep 13, 2006 | 02:00 PM
Micky's Avatar
Micky
.8mm is 30 thou of an inch,regards Micky
Old Sep 13, 2006 | 03:41 PM
davsmith64's Avatar
davsmith64
no probs smeegle
COSSIE 1
Feb 10, 2006 10:17 PM
M K
Jan 5, 2006 11:14 PM
jaiscossie
Sep 26, 2005 05:12 PM
Rob84
Aug 22, 2005 07:13 PM
rabmc
Feb 1, 2005 09:09 PM
