Inlet manifold 1.8 105PS vs 130PS ?
Old Sep 12, 2006 | 11:13 AM
mrazik's Avatar
mrazik
Default Inlet manifold 1.8 105PS vs 130PS ?
Does somebody know if there is some difference between inlet manifold on zetec engine 1.8 105PS versus 1.8 130PS ? inside average ? if yes,how much ?
Thanks
Old Sep 12, 2006 | 01:31 PM
Dave Henshall's Avatar
Dave Henshall
pretty sure the manifolds are the same, its just the throttle body that houses the butterfly that is larger on the 130, along with different cams, ecu and injectors, oh yes, and under piston oil spray jets
Old Sep 13, 2006 | 06:27 PM
PeteS2RST's Avatar
PeteS2RST
have a look at this post it has pics of the two side by side
https://passionford.com/forum/viewtopic.php?t=218235
Old Sep 14, 2006 | 08:13 AM
Dave Henshall
i'll be a monkeys uncle - inlet manifold aswell than
Old Sep 14, 2006 | 12:55 PM
jdfiesta's Avatar
jdfiesta
there are two castings, HO and LO. the 90/105/115ps have the LO, the 130 has the HO
it is a significant difference, hence why i took that picture
JJ
Old Sep 14, 2006 | 06:41 PM
Avinitlarge's Avatar
Avinitlarge
I thought ones said SO and one HO
Nov 1, 2015 06:53 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
Fudgey
21
Sep 30, 2015 06:19 PM
caprixpack
Sep 25, 2015 07:53 PM
