Focus rs engine in ERST
Old Sep 10, 2006 | 04:07 PM
Hansenturbo's Avatar
Hansenturbo
Default Focus rs engine in ERST
anyone running Focus rs engine in a Escort rs turbo if so any pics
Old Sep 10, 2006 | 04:21 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
I'm pretty sure someone on here put it in a FRST, don't know if it was a FRS engine exactly but was duratec turbo
Old Sep 10, 2006 | 09:09 PM
XR2's Avatar
XR2
@Möhle: not enough power yet?
Old Sep 11, 2006 | 03:34 AM
stuart collins's Avatar
stuart collins
will look mate will txt u sum more info on it 2 day
Old Sep 11, 2006 | 07:28 AM
sas's Avatar
sas
should be good!
I have put the block, crank and pistons (short motor) in my ERST but still using the CVH head. Not very good with the camera so no picks.
Old Sep 11, 2006 | 01:01 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
sounds quality
Old Sep 11, 2006 | 01:25 PM
Rab's Avatar
Rab
Fucking superstar........
It's just a zetec. And loads of people have done that
Old Sep 11, 2006 | 02:19 PM
Hansenturbo
No m8 more wants more
Old Sep 11, 2006 | 02:40 PM
sas's Avatar
sas
should be good!
I agree it is very simular to the Zetec, but it does have oil spray jets for the underside of the pistons and the pistons have a 70mm x 3.5mm (approx) dish in them so you have to machine 3 - 4mm off the head or change the pistons.
Other wise the starter fits in the same place as the CVH and the oil filter is on the offside rear.
Old Sep 11, 2006 | 02:54 PM
Hansenturbo
okay thanks m8 i want to run with the 16v head on and a big bad GT turbo on it
Old Sep 11, 2006 | 03:42 PM
Rab's Avatar
Rab
It's not very similar, it IS a zetec...
Old Sep 11, 2006 | 04:00 PM
Hansenturbo
okay is the head ,rods and pistions the same cos in the us they sell stronger rodsand low comp,pistions (for a zetec E ) at a good price
Old Sep 11, 2006 | 04:09 PM
Rab's Avatar
Rab
Yes. The head, rods and pistons are all zetec e stuff.
The pistons were forged items that were pocketed for compression. Ignore the fancy cam cover that has DURATEC on it, it's a zetec. The duratecs had the exhuast and inlet manifolds on opposite sides to the zetec.
Old Sep 11, 2006 | 04:43 PM
sas's Avatar
sas
should be good!
Okay I see, are the oil spray jets standard on all Zetecs or is it a mod for the Focus RS only?
Its my first Zetec/Duratec conversion.
I ordered a new Focus RS short motor from Ford and they called it an early Duratec but as Rab points out it is infact a Zetec, also I know the Duratec is chain driven.
Old Sep 11, 2006 | 04:55 PM
Andy_R's Avatar
Andy_R
Yes!!! Oil spray jets come standard with the Series 3 Zetec's(blacktop)
Old Sep 11, 2006 | 05:01 PM
Rab's Avatar
Rab
There you go.
And why use the CVH head? The 16v head will flow much better
Old Sep 11, 2006 | 05:10 PM
stuart collins
There you go.
cos he wants to use it
Old Sep 11, 2006 | 05:30 PM
JAMSPORT's Avatar
JAMSPORT
the reason for me and simon to use the frs engine is because we had spent exstensive time developing the cylinder head, inlet manifold, turbo, all relevent pipe work and the fitting of gotech management. Unfortunatly time had took its toll on the big end bearings and it was down on oil pressure so rather than rebuilding the 1.9cvh it was cheaper to use more modern off the shelf readilly avaliable items plus it would have taken longer too rebuild the 1.9. Also we carry steel rods to suit that engine which then gave it even more strength and reliability
I agree that the engine could produce more power with a correct spec,d 16v head but again it would cost more and take longer still
Once the car is run in and mapped we will see the true potential of the 8v head again
as we have seen 350+ bhp on my efi cvh head with standard valves proven (stuart collins 1.6 cvh)
regards
Jamie at jamsport
Old Sep 11, 2006 | 07:12 PM
Rab's Avatar
Rab
regards
Jamie at jamsport
Well, that fair enough. I just think it's a shame to buy a 16v zetec then chuck away the best bit.
I'm sure you know what you're doing.
How much is a FRS engine from Ford? Just out of curiosity you understand
Old Sep 11, 2006 | 07:19 PM
sas's Avatar
sas
should be good!
I just bought the short motor, and it was less than a set of forged pistons and rods for the CVH.
Old Sep 11, 2006 | 07:46 PM
Rab's Avatar
Rab
Thats impressive. So about 1500 notes then?
RUBY123
Oct 22, 2023 12:04 PM
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
