oily exhaust chamber
Old Sep 10, 2006 | 01:24 PM
vodoo1's Avatar
vodoo1
Default oily exhaust chamber
taken my turbo of my 2lt zvh to have a new turbo fitted ( was smoking) but looking at the exhaust chambers on the head and there oil in the number 1 exhaust chamber is this valve stem seals gone ? as i did replace them all when i got the head a few months ago
Old Sep 10, 2006 | 07:58 PM
Rick's Avatar
Rick
possibly yes - but but it could also be a valve guide problem. You should be able to see by stripping off the rocker gear again - head in situ. Might be nothing wrong with the turbo!
Old Sep 12, 2006 | 07:15 PM
steven botes's Avatar
steven botes
found a problem with new valve oil stems leaking myself - what i did find was that if you dont lube the top of the valve stem that the cotter fits into , the can damage the seal when installing the valves
Old Sep 12, 2006 | 08:35 PM
Rick's Avatar
Rick
steven botes
Very true!
tankybaby66
Feb 6, 2016 02:24 PM
Cosnada
Jan 7, 2016 05:30 PM
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
