series 2 wont start
Old Sep 10, 2006 | 11:04 AM
rstel1's Avatar
rstel1
Default series 2 wont start
ello everyone i have a 1988 series 2 and i was out in it a few nights ago when it sudenly cut out as i was just parking up it will turn over but the fuel pump does not prime up,which made me check the fuses and they was ok, so i thought maybe the relay under the dash. whoever thurther inspection made me notice i have not indicators,electric windows or oil abs lights on my dash?? (maybe a fuse box fault). so not to shure please healp
Old Sep 10, 2006 | 11:33 AM
gup's Avatar
gup
is your alarm still working
check the black multiplug under the steering coloum from ignition to c if this has come away
Old Sep 10, 2006 | 12:00 PM
rstel1's Avatar
rstel1
yeh my alarm is ok i have a clifford and if the immobiliser is on i wont even turn over as it is a multi point immobiser
Old Sep 10, 2006 | 03:32 PM
gup's Avatar
gup
check the fuses under the dash for the alarm as they could of blown seperate circuits might use in line fuses
are you getting a live to the pump try wiggling the fuses in the fuse box and relays to c if their is a bad connection somewhere
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
xrmalin
Sep 13, 2015 06:52 PM
stevierob
Sep 7, 2015 07:09 PM
gingeRS
Sep 4, 2015 06:29 PM
turbowag
Sep 3, 2015 08:07 AM
