The hard work was worth it !!
Old Sep 9, 2006 | 04:54 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
From: Under the water.... .......in a nuclear submarine
Default The hard work was worth it !!
Today went to local rolling road with Trev so he could get his CO set correctly so it would of been rude not to try out the new Dyno Dynamics rolling road
What a great piece of kit, no movement of the car at all even when it comes on boost
And the result was quite pleasing as well Should make 400bhp on a cooler day, although the charge air temp never went over 33
Thanks to Alan @ www.enginetuner.co.uk
Old Sep 9, 2006 | 05:11 PM
foreigneRS's Avatar
foreigneRS
Testing the future
did they measure the charge air temp? they normally only put the sensor at the air filter. or were you reading it from SECS/Pectel monitor?
Old Sep 9, 2006 | 05:14 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Not being funny but i always thought power and torque should cross at 5252rpm.
What spec are you running ?
Steve.
trevCOSS's Avatar
trevCOSS
The SECS was reading 33 and the ambient in the workshop was 25.
Old Sep 9, 2006 | 05:17 PM
JohnnyB's Avatar
JohnnyB
the axes are out comon with the tacko sig not right
Old Sep 9, 2006 | 05:25 PM
foreigneRS's Avatar
foreigneRS
Testing the future
not again. where's SECS?
they should only cross at 5252 rpm if the axes are the same scale, and the units are bhp and lb.ft
Old Sep 9, 2006 | 09:41 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Thats what they look like to me on the graph
Steve.
Old Sep 9, 2006 | 09:42 PM
dave cos4x4's Avatar
dave cos4x4
Old Sep 9, 2006 | 10:20 PM
trevCOSS's Avatar
trevCOSS
the power and torque axis are not the same scale hence why they dont cross at the right place, they are not the same scale because the software on the dyno dynamics road allows you to change the scales for each axis and this is obviously what the operator has done.
Old Sep 9, 2006 | 10:21 PM
trevCOSS's Avatar
trevCOSS
Oh forgot Yes Rich it was indeed worth it
Old Sep 10, 2006 | 02:45 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
I should of looked at the graph harder
I can see it now
Still want to know the spec that its running.
Steve.
Old Sep 10, 2006 | 03:52 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
I can see it now
Steve.
SCS spec T38, 850cc Siemens Injectors, Swedish Style plenum and a RS500 sized intercooler. Standard comp with an unmodified head and standard cams.
Old Sep 10, 2006 | 04:47 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
What boost ?
Steve.
Old Sep 10, 2006 | 04:48 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
What boost ?
Steve.
peaks@31 and holds 25.
Old Sep 10, 2006 | 04:50 PM
KSA-Cossie's Avatar
KSA-Cossie
Nice figures m8.
Old Sep 10, 2006 | 04:54 PM
ECU Monitor Enthusiast
B9KOS,
Sweet
foreigneRS,
Coooont
Old Sep 10, 2006 | 06:11 PM
Danny @ Enhanced Performance's Avatar
that looks very laggy what made you go for such a big turbo and injectors?when you running a std engine?has that been mapped like that or have you used a base map of some sort?we done same engine but on 4 greys and bd 14 inlet and it made 428bhp and 426lb ft at 4432 revs also by 4.5k it was pulling nearly 300 bhp.if you want a better map give me a shout or get it live mapped by stu at msd
Old Sep 10, 2006 | 06:20 PM
trevCOSS's Avatar
trevCOSS
Originally Posted by abc motor sport
that looks very laggy what made you go for such a big turbo and injectors?when you running a std engine?has that been mapped like that or have you used a base map of some sort?we done same engine but on 4 greys and bd 14 inlet and it made 428bhp and 426lb ft at 4432 revs also by 4.5k it was pulling nearly 300 bhp.if you want a better map give me a shout or get it live mapped by Stu at MSD
Old Sep 10, 2006 | 06:36 PM
treCOSS . well answerd questions mate not having a dig just asking questions
Old Sep 10, 2006 | 06:44 PM
pau1rs's Avatar
pau1rs
look here mate...
https://passionford.com/forum/viewtopic.php?t=197503
just back from msd i believe!!!
Old Sep 10, 2006 | 07:00 PM
cheers paulrs i suppose the rest of us have to be mind readers ah.well power is poor maybe stu is being safe or something but there isnt much of a power spread and with std head and cams and comp ratio its normaly very lively but not that one maybe its lower comp ratio than he thinks
Old Sep 10, 2006 | 07:02 PM
fordsportjay's Avatar
fordsportjay
it was at msd when my rs500 was being done being live mapped-looked a good bit of kit
Old Sep 10, 2006 | 07:32 PM
Graceland's Avatar
Graceland
Team HOTHOT!
Well done Richie - I know how much of a struggle this has been for you to get the car finished
Looking forawrd to my passenger ride in her on any road
Old Sep 10, 2006 | 07:34 PM
Graceland's Avatar
Graceland
Team HOTHOT!
cheers paulrs i suppose the rest of us have to be mind readers ah.well power is poor maybe Stu is being safe or something but there isnt much of a power spread and with std head and cams and comp ratio its normaly very lively but not that one maybe its lower comp ratio than he thinks
Maybe that is what Richie wants from his car?
you just don't know unless you ask him
trevCOSS's Avatar
trevCOSS
sorry I was going to come back and explain but got caught up, and thought rich would have been right on here anyway. As you know know the car was mapped at msd recently, Im sure rich was more than aware what kind of result he might get with the choice of parts, I suppose you could say he's future proofing it, all it needs now is a the right head & cams to make the most of the ancillary components, which where chosen for there good prices and availability (largely second hand from here) as well as the ability to do more in the future. The car is as you say a bit laggy but drives very well and feels much better than the curve posted might suggest.
Old Sep 10, 2006 | 07:56 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
Originally Posted by fordsportjay
it was at MSD when my rs500 was being done being live mapped-looked a good bit of kit
Cheers Jay, yours looked proper hard on the MOs
Old Sep 10, 2006 | 07:59 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
Old Sep 10, 2006 | 08:09 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
sorry I was going to come back and explain but got caught up, and thought rich would have been right on here anyway. As you know know the car was mapped at MSD recently, Im sure rich was more than aware what kind of result he might get with the choice of parts, I suppose you could say he's future proofing it, all it needs now is a the right head & cams to make the most of the ancillary components, which where chosen for there good prices and availability (largely second hand from here) as well as the ability to do more in the future. The car is as you say a bit laggy but drives very well and feels much better than the curve posted might suggest.
Hi Danny, the final spec changed alot from the original 803s and 23psi boost plan. Like trevCOSS said as we built the car up i bought a lot of bits off Passionford to future proof the engine, for example the injectors flow more than 8x403s but are only on 38% duty when pulling 7000rpm in 4th Better than running the 803s flat out i think you'll agree
The only thing limiting the power now is the engine internals. Had the engine not only just been run in i would of gone low comp and had some headwork and cams , but that can wait till this one goes pop
Old Sep 10, 2006 | 10:03 PM
Jay,'s Avatar
Jay,
Sponsor
cock
Old Sep 10, 2006 | 10:08 PM
Stu @ M Developments's Avatar
PassionFords Creator
Shame theres no boost mapped onto that graph as i am confident your engine produced nearer 400ftlb of torque Pal.
I would say the boost was a tad low on teh rollers due to lack of load, and of course boost is all important at high revs when your VE is falling off. The power most certainly does not peak at 6k on the road i am sure you will agree?
Car goes well in the real world, its a fast car.
Old Sep 10, 2006 | 10:11 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
I would say the boost was a tad low on the rollers due to lack of load, and of course boost is all important at high revs when your VE is falling off. The power most certainly does not peak at 6k on the road i am sure you will agree?
Cheers Stu It goes very well especially now i'm using your revised rev limit Gearbox isn't liking it though
He didn't connect an inductive pick up to the leads, only a boost sensor so not sure how the rpm axis is derived
Old Sep 10, 2006 | 10:50 PM
well done b9kos not every every r/r graph shows a true story of how the car performs and like stu says if it feels quick and more like 400 lb ft then thats a quick car.cheers for explaining why you got your spec it was a bit confussing but i agree you now have a lot of scope for the future.as for you jaycos fuck of you twat
Old Sep 10, 2006 | 10:52 PM
Brian's Avatar
Brian
Brian
Old Sep 10, 2006 | 10:55 PM
Jay,'s Avatar
Jay,
Sponsor
sorry i meant to say shonky cock
Old Sep 10, 2006 | 11:05 PM
jaycos i bet your car is wicked on dta you knobhead.we used it once and once only what a pile of shit.jaycos is one of them mouthy cunts who thinks he knows everything and slags others of behind hes computer you nutter come on let yourself be known.
Old Sep 11, 2006 | 07:23 AM
Jay,'s Avatar
Jay,
Sponsor
let myself be known
wicked on! dta yes it is it does me just fine
mouthy cunt behind a keyboard. people who know me on here know different as i will say to the face more so
you tried dta once well learn how to use it then as a good tune will say a bad tuner will always blame his tools
as stu once stated the only prob with dta is haveing to swap screens when mapping
Old Sep 11, 2006 | 08:38 AM
come see me face to face then hard man.as for dta its crap everyone knows that but hey thats why you need such big injectors the ecu is so slow.if you want to slate me as a business when you know fuckall about me then lets meet up and see how far you get.you can say what you want to my face and see who your slating oir better still come down to work and see all the big jobs weve got on and show us how youd do it better you clever cunt
Old Sep 11, 2006 | 08:44 AM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
fuck off with your billy big balls attitude rofl
Old Sep 11, 2006 | 08:50 AM
i wonderd how long it would be before someone else butted in.well its very easy to get on a keyboard and be hard so i expect loads of knobheads to now.carry on thats the end from me untill some one has got the guts to slate me to my face
