ISCV
Sep 9, 2006 | 03:23 PM
ISCV
Idle Speed Control Valve, it looks to be joined to water hoses also with a temp sensor or something. can they be seperated??
how do I test the ISCV?
thanks
Sep 9, 2006 | 04:03 PM
Sep 9, 2006 | 04:29 PM
Sep 9, 2006 | 04:37 PM
Thats not an ISCV mate
Auxiliary air device, only controls warm up idle. Only 2 screws to remove it. What problems are you having?
Sep 9, 2006 | 07:45 PM
won't idle, no air leaks, is there an idle control valve?? I've adjusted screw to max
Sep 10, 2006 | 07:00 PM
No, the idle screw is the only means on this. Won't it idle when hot or cold?
DixieTheKid
11
Jun 6, 2020 11:20 AM
RSmark84
Sep 13, 2015 01:29 PM
cozzy jeff
Sep 12, 2015 04:32 PM
muffster
13
Sep 3, 2015 09:40 PM
Cosnada
Aug 27, 2015 09:15 AM
