crunchey gears
hello there.
it sometimes is difficult to get my car into gear, especially reverse, the car has a padle clutch in it and the clutch doesnt slip at all so i presume its not the clutch. So any ideas, to my mind it leaves, clutch cable/gear selectors need adjusting or box itself is on way out.
anybody got any ideas?
cheers
cheers
Originally Posted by SafeChav
I'd say the clutch isn't disengaging properly. Does the car "creep" at all if you are in gear with the clutch pedal depressed?
also mine is hard to get into gear and reverse like yours scott
whats the cause?
It can be 2 things, the quadrant not working or the thrust bearing/springs going on the clutch.
scottbrown if your clutch is fairly new it may well be the quadrant at fault.
TURBO BOI yours could well be the clutch is on its way out, is the pedal very heavy, and does it ever judder or "squeal" when you pull off?
shall i give it the 2nd gear handbrake on pull away jobby test? to see if it slips or stalls?
ENGLISH VERSION
1. Put automobile into 2nd gear
2. Operate handbrake lever so that it is fully on
3. Try to pull away as normal
4. if car stalls, clutch is ok
5. if clutch slips, clutch is FU@KED
hows thats
hows thats
Originally Posted by scottbrown
quadrant????
mine doesnt skeel or slip even at full boost but sometimes judders on pull away
The squealling noise (thats how i would describe it anyway) alos happens when pulling off, usually when the clutch is VERY worn though. For examply my Orion has got its original clutch and is on 108k, that worn
Uprated clutches do tend to judder, i'd say for you its probably the quadrant failed, MK6 pedal conversion would be a good mod
wanted say the pedal was very heavy and its not juddering or squeling at the moment
i caun typer 2000 wotrsd aminute youy knowa
(sorry shit joke)i ment to write "i wouldnt say the pedal was heavy"
quadrant????
Close the door on your way out safechav
NEED MORE INPUT
scottbrown, its not very hard, theres a guide on the AP website. Basically you change the pedal for a MK6 one, it has a bigger quadrant aswell, so that makes the pedal both lighter, and gives more lift, aswell as havign a screw to adjust it, so theres no risk of the adjuster breaking
What does the pedal feel like now? Does it feel nice, or not? (hard question i know
TURBO BOI
TURBO BOI
NEED MORE INPUT
TURBO BOI
TURBO BOI
so its just the actual pedal i need from a mk6? what about cable? do they fit straight on?
Hmmmmmmm, have you got the highest spec clutch?
You need the pedal itself, and 58mm WHITE quadrant, NOT the 55mm black one (the AP website is wrong) and its worth getting the 2 plastic bushes that fit into the pedal just for good practice.
heres the page that describes the rest. It should fit straight on
http://www.apracing.com/roadcar/clutch/epmods.htm
Its not that hard, its fiddly under the dash though if you don't remove it
That quadrant is easy to cut, or if you're feeling extra brave, GRINDER
I tried cutting a bumper once with a grinder, never again. lol
The Youth.
Sep 30, 2015 09:59 PM
