2.1zvh conversion
Old Sep 7, 2006 | 11:02 PM
TURBO BOI's Avatar
TURBO BOI
Default 2.1zvh conversion
Which block is used? is it a 2.0 mondeo?
Old Sep 7, 2006 | 11:05 PM
Rab's Avatar
Rab
Fucking superstar........
Yes, the mondeo 2.0 silver top zetec bottom end is best. But, why throw away the most effective part? The 16v head.
You're on EFi now so that'd run a ZT easily. Buy a mondy 2.0 engine, slip a de-comp plate in and you've got an easy 230-250bhp.
Old Sep 7, 2006 | 11:08 PM
TURBO BOI's Avatar
TURBO BOI
with my turbo bits?
Old Sep 7, 2006 | 11:11 PM
Rab's Avatar
Rab
Yup.
The managment would need chipped and mapped specifically for the engine, which may cost a few quid, but you'd be doing it anyways for the ZVH.
Old Sep 7, 2006 | 11:13 PM
TURBO BOI's Avatar
TURBO BOI
do you know the story with the gearbox? zetec box required?
will my cvh manifolds fit the zetec head?
Old Sep 7, 2006 | 11:16 PM
Rab's Avatar
Rab
You can get adapter plates made for the zetec. And your BC box will be fine.
Old Sep 7, 2006 | 11:20 PM
TURBO BOI's Avatar
TURBO BOI
i got my rpm pick up at the crank pulley at the mo were are they on the zetecs?
am i looking at quite abit off money for zetec engine tho
Old Sep 7, 2006 | 11:29 PM
NEWTON's Avatar
NEWTON
there on the flywheel,so you would need a fes turbo flywheel as well
Old Sep 7, 2006 | 11:33 PM
TURBO BOI's Avatar
TURBO BOI
reckon i could use my sierra 1.8 pulley for the pick up still? its quite a chunky pulley and nearly touches the side of the engine bay on my cvh block, are zetec blocks wider?
Old Sep 7, 2006 | 11:36 PM
TURBO BOI's Avatar
TURBO BOI
mind you if i get a fezzy flywheel anyway i could lighten it ect
NEWTON's Avatar
NEWTON
dont think it would fit,just get a efi flywheel xr2i or rst prob solved
Old Sep 7, 2006 | 11:42 PM
TURBO BOI's Avatar
TURBO BOI
ive just read that the 2.0zetec flywheel doesnt fit into the cvh box anyway so i gota get a frst flywheel anyway
Old Sep 8, 2006 | 03:42 PM
XR2's Avatar
XR2
Yes, Zetec flywheels for MTX Gearboxes are much too big. And maybe you can spend a few pounds on pistons then forget that decomp plate crap
Old Sep 8, 2006 | 06:25 PM
scotty86d's Avatar
scotty86d
if you're really tight skim the pistons like ive heard people do with pretty good results
Old Sep 8, 2006 | 10:53 PM
NEWTON's Avatar
NEWTON
yes listen to this guy
mk3ste
Oct 17, 2021 10:09 AM
Nov 1, 2015 06:53 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
SMILER258
Sep 28, 2015 09:04 AM
mpilk
Sep 27, 2015 09:21 AM
