What Brake Pads
Old Sep 7, 2006 | 08:40 AM
Ryan's Avatar
Ryan
Default What Brake Pads
AP 6 Pots - CP5555
3dr Cosworth
Mainly to be used on the road, but the ocassional track day
Any advice?
Ryan
Old Sep 7, 2006 | 09:28 AM
Ryan's Avatar
Ryan
Old Sep 7, 2006 | 09:43 AM
Eagle's Avatar
Eagle
Super Moderator
ferrodo ds 2500 ..
there are different heights of pad tho
speak to rainbird he does very good deals on em
Old Sep 7, 2006 | 09:54 AM
Redkop's Avatar
Redkop
Ferodo DS2500s definitely
Old Sep 7, 2006 | 09:57 AM
Ryan's Avatar
Ryan
are they ok on the road? i.e dont take ages to heat up?
and dont eat through discs?
Old Sep 7, 2006 | 10:01 AM
Redkop's Avatar
Redkop
Fine on the road, heat up fine and don't eat discs.
Old Sep 7, 2006 | 10:02 AM
Ryan's Avatar
Ryan
cool , will get some off steve today then
Old Sep 7, 2006 | 10:06 AM
JTECH James's Avatar
JTECH James
Passion for Fords!
they do eat discs!!!
my set of standard size ds2500 pads are on there second set of discs
Old Sep 7, 2006 | 10:12 AM
Ryan's Avatar
Ryan
oh
Old Sep 7, 2006 | 10:16 AM
Redkop's Avatar
Redkop
Just changed discs and pads on mine, they were on for over 2 years and did lots of trackdays too.
JTECHSAFF
You put on new discs without new pads?
Old Sep 7, 2006 | 10:17 AM
JTECH James
Passion for Fords!
they are wicked pads though! i would deffo reccomend them, if you have loads of wheel cleaner to hand!!
Old Sep 7, 2006 | 10:18 AM
JTECH James
Passion for Fords!
they were like brand fookin new...... at Ł90 quid a go i aint throwin them away, within a week the grooves on the brand new discs had gone!
Old Sep 7, 2006 | 10:19 AM
Ryan's Avatar
Ryan
jtech, what size discs are you running?
Old Sep 7, 2006 | 10:20 AM
Redkop's Avatar
Redkop
What discs?
Old Sep 7, 2006 | 10:22 AM
JTECH James
Passion for Fords!
national sport grooved jobbies. standard size.
The pads are now just off half worn, and the second set of discs are shagged, no grooves left, big lip on the edge.
Old Sep 7, 2006 | 10:23 AM
JTECH James
Passion for Fords!
i want big brakes like you guys have got,
Old Sep 7, 2006 | 10:24 AM
Ryan's Avatar
Ryan
oh well that could be due to heat build up then.
i have 355x32mm
so hopefully will last loads longer
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
i use them front(6pots) and back groved they get used everyday + track,the ring and cant say owt bad about them,but yes a lot ov dust if ur a buffty
Old Sep 7, 2006 | 10:26 AM
JTECH James
Passion for Fords!
most of the dust from mine is the fookin discs!!
Old Sep 7, 2006 | 10:28 AM
Ryan's Avatar
Ryan
oh bugger, my wheels are the worst wheels ever to clean.
and i am a fookin bufty
Old Sep 7, 2006 | 10:30 AM
JTECH James
Passion for Fords!
its ok for me, i can collect the disc dust with a magnet!
Old Sep 7, 2006 | 10:33 AM
Porkie's Avatar
Porkie
You won't ever finish let alone drive this car!!! so get the cheapest ones or easiest to sell on!
Old Sep 7, 2006 | 10:35 AM
Redkop's Avatar
Redkop
Could be the discs are crap then. I have AP discs and even my old ones had the grooves left, ^Nutter^ has them now as they can easily be skimmed.
Edited to add.... yep they do cause a lot of brake dust.
Old Sep 7, 2006 | 10:37 AM
pete mcrash
sounds like sum top quality items uve got there....
Old Sep 7, 2006 | 10:39 AM
JTECH James
Passion for Fords!
what are the bestistisisisit standard size discs then smarty pants?
Old Sep 7, 2006 | 10:41 AM
Ryan's Avatar
Ryan
porkie you cooont, your car is off the road just as much as mine
but it will get finished, i've come too far, and invested too much money not too.
Plus it will be an awesome car when done.
Old Sep 7, 2006 | 10:42 AM
Redkop's Avatar
Redkop
Obviously not the ones you have
Old Sep 7, 2006 | 10:44 AM
JTECH James
Passion for Fords!
i did ponder the thought they may not be top top quality when the instuctions said , keep refrigerated, as contents may melt.
Old Sep 7, 2006 | 10:46 AM
pete mcrash
must have fukn been made by cadburys me thinks fella
Old Sep 7, 2006 | 10:49 AM
pete mcrash
standard i had tarox,but pay a bit more and go 4 red dot, two of my pals swear by them...... but fuk standard go massive..... get the visa owt
Old Sep 7, 2006 | 11:04 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
I am confused as DS2500s shouldn't eat discs . If you had said that about DS3000s, then I would agree, but not DS2500s - are you sure somebody hasn't sold you DS3000s by mistake? What is the reference on the pads?
As to Ryan, I would recommend TWO sets of pads - DS2500 for the road and DS3000 for the track.... Prices are on my website for all AP sizes (check disc height though).
Old Sep 7, 2006 | 11:08 AM
Redkop's Avatar
Redkop
I think it's the type of discs he has Mike....
Old Sep 7, 2006 | 11:09 AM
RichardPON's Avatar
RichardPON
Don't use PF Carbon Metallics.
They may stop the car VERY well, but they eat discs for breakfast, and end up leaving metallic brake dust up the side of the car!
JTECH James
Passion for Fords!
plastic ones!!
Old Sep 7, 2006 | 11:14 AM
Redkop's Avatar
Redkop
plastic ones!!
Old Sep 7, 2006 | 11:16 AM
JTECH James
Passion for Fords!
ahh but at least i can cut new grooves in them with a soldering iron!! clever!!!
Old Sep 7, 2006 | 11:48 AM
Ryan's Avatar
Ryan
DS2500's it is then
Old Sep 7, 2006 | 11:57 AM
NUTS RuS's Avatar
NUTS RuS
Its normal and correct to bed in new discs on old pads, or vice versa, you should generally bed in new pads on old discs.
Old Sep 7, 2006 | 12:22 PM
Redkop's Avatar
Redkop
I have always been told > new discs > new pads.
I had to wait 7 days for my pads after I fitted the discs so drove with the old ones on, they made the discs look awful.
Old Sep 7, 2006 | 12:23 PM
JTECH James
Passion for Fords!
i machined them flat first ,im not that shonkey!
