-31 ACTUATOR?
Old Sep 6, 2006 | 11:07 PM
Maxxeh's Avatar
Maxxeh
Default -31 ACTUATOR?
I kno what an actuator is but whats so special about this one?
Sorry im a n00b.
Old Sep 6, 2006 | 11:15 PM
Rick's Avatar
Rick
-31 is the end of the garrat part number.
A -31 actuator is usually the next step up in spring pressure from the standard item. After that, it is the -34.
Std is 4psi lift off, -31 7-8psi. -34 14psi.
These lift off values represent the lowest boost you can run with that actuator.
JK12
33
Apr 26, 2021 12:09 PM
steve.rst
Mar 15, 2016 08:01 AM
A.t.p
Sep 29, 2015 05:04 PM
rs_jim
Sep 19, 2015 08:41 PM
wheelwizardrefurbs
Sep 18, 2015 02:39 PM
