ABSOLUTELY STANDARD Escort Cosworth - 262.6BHP, 296.1FT/LB..
... because it's overboosting like a bastard!
Been to a rolling road session at AMD Technik in Bister today, and got some suprisingly wobbly dynoplots. Martin at AMD (who has a lot of Cossie experience - and seems a thoroughly nice bloke) took it for a quick blast up the road and concluded that either the wastegate actuator or recirculating valve (did I get that right? I forget exactly what he said) was knackered!
Anyone got an idea on costs for getting it sorted?
Cheers!
Cheers!
About £60-70 for an actuator, the recirculating valve(dump valve) cannot be much from Fords.
Cannot see it being that though.
Dave.
Originally Posted by Itsmeagain
Id recirc valve was fucked itd lose boost, 15quid from ford i think, for a tuner to say that id say he hanst a clue
I'm not in a position to comment really, as I know f**k all when it comes to engines, hence posting on here
boost would back off as soon as you lifted, all turbo cars do unless you got anti-lag
ECU retarding ign isnt so much of a problem, hitting the boost limit or detting would be
what boost was it actually running?
And if it was that bad, why the fook did they do a full run?
If the actuator was mullered then the boost wouldnt hold, as has been said concerning a mullered dump valve.
Cant see how the wastegate can stick unless something is bent/twisted etc.
The boost is closed loop on P8 isn't it, so therefore the ECU constantly monitors and adjusts the amal valve doesnt it? It hasn;t got a bleed valve or been chipped has it?
To get 296ft/lb (assuming the reading is accurate) and the car is standard, it will have to be boosting a fair bit higher then standard.
I doubt very much that the ECU can compensate on ignition for that much boost on a standard set-up!
Originally Posted by Jim Galbally
he could have been discussing the amal valve...
as for the boost "backing off" its SUPPOSED to do that :P
So, aside for leading others to doubt the competency of the AMD boys, is there a consensus on what needs doing and how much it's gonna cost me? A new wastegate actuator at £70 plus fitting?
I'm aware I appear to be clueless on this - that's because I am!
But I'm keen to learn.
Julian,
I would get it to someone that is able to diagnose and repair the problem mate. You could end up doing some damage if you don't. Drive off boost until you get it sorted.
Good luck.
Good luck.
Anyone got any recommendations in the Sussex area?
Did they check the fuelling on the RR run?
Unless their RR over reads, I'd say check to see if your ECU's been chipped.....
Don't forget, std EsCos DOES overboost (given the correct conditions) as it was designed to..... Worth checking plastic pipes to and from the EsCos Lektron valve (similar to an amal valve) are all connected.
I f it is over boosting as you say this would of shown on the rollers why did they push the engine to the limit before saying...."erm I think theres a problem" they should of aborted the run... lucky your engine didn't go pop...
As you don't say what boost it was running I suspect it was a false reading 'dabed the brakes or somthing'
mark
jessie_rs
11
Jun 3, 2019 04:57 PM
