External Wastegates
Old Sep 6, 2006 | 02:00 PM
Ryan's Avatar
Ryan
Default External Wastegates
Is one as good as the other? or is there a massive difference between a good and a bad one?
Any help much appriciated
Old Sep 6, 2006 | 02:02 PM
Kelv's Avatar
Kelv
Almost there!
the main differences Ryan is that a good one is good
and therefor a bad one is bad
Old Sep 6, 2006 | 02:13 PM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
Tial are supposed to be good. Warren had a copy of a Tial on his and it worked fine. Ask Sheady, he will tel you wahts best
Old Sep 6, 2006 | 02:15 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
As long as its big enough, to make the boost low enough, on the size turbo you want, on the size engine you want, then its good enough.
Turbosmart ProGate is good for the money IMO.
Id have some good ones id sell you, but i forgot to order them, maybe soon, maybe
Old Sep 6, 2006 | 02:16 PM
Ryan's Avatar
Ryan
yeah thats what made me think, warrens is a cheap verison and works perfectly well.
so i wondered are you purely paying for "the name" same in most cases, or did he just get lucky?
Old Sep 6, 2006 | 02:18 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
As long as its a copy made by the RIGHT company, then its no problem
I can get copies that still say Tial on them if you that fussy
Old Sep 6, 2006 | 02:20 PM
CossieRich's Avatar
CossieRich
I think he just got lucky with the one he chose tbh Ryan. i dont think there was any research done or anything lke that.
Old Sep 6, 2006 | 02:48 PM
Jay,'s Avatar
Jay,
Sponsor
so can u buy one of martooons elbows and put any wastegate on it
Old Sep 6, 2006 | 03:09 PM
Vic's Avatar
Vic
Ryan,
it all depends on the application. If its only a street car, a copy of a TiAL or HKS would be sufficent. Just make sure the valve seats properly or else you'll have a leaky watsegate. If your running lots of boost, racing and/or have hight exhaust temps, an 'expensive' one is your only option.
The extra price you pay for is for superior meterials such as inconnel valves.
Intially Turbosmart ones bent valves with high exhuast temps. I've seen this happen first hand at least 3 times and I also heard Brom had problems with his. Having said this, I understand they have rectified this problem and its popularity is a good indicator of the good price/performance you get from Turbosmart.
I've used a TiAL previously and I reckon they would have to be one of the best made wastegates out there. I currently have a 50mm HKS GTII wastegate that I'd highly recommend, but not for your wallet!!
Old Sep 6, 2006 | 03:13 PM
Vic's Avatar
Vic
Oh yeah. NEVER buy a 2nd hand wastegate. I bought one from a Sports Sedan (Thundersaloon) a few years back and even though it was one of the same ones used in 90% of WRC cars (cant remember the co. that made them) it was bent like f*ck!
Ryan's Avatar
Ryan
many thanks for the info Vic, very informative.
dont need anywhere near 50mm for my application, i've been told 45mm is the maxium i would ever need.
I have been looking at the tial and turbosmart/pro gate ones
SapphyMike's Avatar
SapphyMike
no.
he would beed your external wastegate to make sure the end it fits on is correct.
My brother runs a Tial on his, and its up to the job.
Old Sep 6, 2006 | 03:17 PM
Porkie's Avatar
Porkie
My Turbosmart one has been faultless. Bad piccy sorry.
Old Sep 6, 2006 | 03:18 PM
Ryan's Avatar
Ryan
yeah the pro gate 45 is the one i was looking at.
Old Sep 6, 2006 | 03:28 PM
Vic's Avatar
Vic
Glad to be of help Ryan.
here's a pic of what's on my car this week
Old Sep 6, 2006 | 03:31 PM
Jay,'s Avatar
Jay,
Sponsor
porkie wat manifold are you useing chap
Old Sep 6, 2006 | 03:33 PM
Ryan's Avatar
Ryan
vic your probably as bad as me, something gets changed every week on my car.
and jay its a standard manfiold with a pipe modded of the original swan neck
Old Sep 6, 2006 | 03:34 PM
Porkie's Avatar
Porkie
Modded 2wd one mate. Works fine at my power level... and no cracks! I think you want need a tubular one for much more than 630bhp though.
Old Sep 6, 2006 | 04:08 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Martin uses and recommends the Tial ones and does them for a very good price (see his website). These are the ones that Harvey also uses .
Old Sep 6, 2006 | 04:11 PM
sunny's Avatar
sunny
Very happy with my turbosmart one. Will be using it again on my new engine.
Old Sep 6, 2006 | 04:12 PM
Kelv's Avatar
Kelv
Almost there!
im glad of that then
my 2wd swan neck is martins modded one with a tial wastegate
Old Sep 6, 2006 | 04:37 PM
...well i am goin Reyland Tial is the one to get no idea what size i am getting though LOL.
Fooking hell..a MAD engine with a touch of Reyland and Norris
Old Sep 6, 2006 | 04:43 PM
Ryan's Avatar
Ryan
kelv, no yours isnt a reyland pipe.
Its PJ item.
As its a cast item, not a fabricated one.
Old Sep 6, 2006 | 04:44 PM
Disabled Account's Avatar
Disabled Account
Ryan, I use & reccomend the Turbo-Smart 48mm unit...............it's worth checking the internal rubber/neoprene diaphram for holes/splits from time-to-time......cheap & easy to replace the diaphram anyway, they are prone to this problem AFAIK.
Old Sep 6, 2006 | 04:49 PM
..i am gonna use a screamer pipe...is this very noisy?...Oh and is it ok to put it as a side exit pipe?...i dont want to kill anyone or set light to a passing car when i am giving it large!
Old Sep 6, 2006 | 04:56 PM
Kelv's Avatar
Kelv
Almost there!
Its PJ item.
My mistake then
Old Sep 6, 2006 | 04:59 PM
Disabled Account
Phil, did'nt you say a couple of years ago that screamer pipes are dangerous, because they cause the front end of the car to lift up in the air? I'm sure it was you that posted that
Old Sep 6, 2006 | 05:21 PM
...that is correct a VERY famous tuner of a different make car told me this...BUT as you well know it is when you point the exhaust straight down the turbulence can be dangerous when doin a top speed run....so as i said i wanted to do it side exit.it aint in any way dangerous in a top speed way.
Old Sep 6, 2006 | 05:23 PM
Ryan's Avatar
Ryan
phil a screamer pipe is very very noisey if vented to atmos.
and i fookin love the noise.
no good for track, but yours is never going to see track, so thats that solved.
makes your ears ring after a good blat though.
Old Sep 6, 2006 | 05:29 PM
...does it or can it spit flames?..As i want it to come out drivers side to onme side of the front jacking cover.
Old Sep 6, 2006 | 05:41 PM
Ryan's Avatar
Ryan
not a clue on that one phil.
Old Sep 6, 2006 | 05:50 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
Ryan, What turbo you going for now then?!
Old Sep 6, 2006 | 05:52 PM
peteh's Avatar
peteh
GT30 i think
Old Sep 6, 2006 | 05:56 PM
Ryan's Avatar
Ryan
gt30 rad.
Old Sep 6, 2006 | 05:58 PM
Charlie Chalk
Unknown.
Nice one mate
Old Sep 6, 2006 | 06:01 PM
Alg1k's Avatar
Alg1k
I have mine exiting just behind the front wheel
Its fuckin noisey
If you have the window open your eyes start to sting with the ex fumes and yes
a couple of times it has shot some big flames out when i came off boost and then reaplied full throttle
Old Sep 6, 2006 | 06:24 PM
...cheers ALG1K...i think i will just keep it under the car in a safe place!!!
Old Sep 6, 2006 | 06:30 PM
Charlie Chalk
Unknown.
Alg1k
Do you have a silencer on it?
as you take your car on track....Just wondered with noise regs etc
Old Sep 6, 2006 | 07:05 PM
pgt9's Avatar
pgt9
clairfication on a 'screamer' please is it simply that the waste gate flows direct to atmo rather than down the exhausts pipe?
presumably if this is the case then its only noisy when the waste gate opens and that would be ok for scrutineering?
Old Sep 6, 2006 | 08:26 PM
Liams's Avatar
Liams
pgt9, yes thats correct. things will only get noisy once you hit your desired boost pressure/wategate opens.... drive around like a granny and you'd never know!
