Central heating prob
Old Aug 21, 2004 | 05:18 PM
The Sludge's Avatar
The Sludge
garibaldi
Default Central heating prob
3 yr old sytem running vailliant 828 turbo. Turned it on today ( cos of baby) and no heating either upstairs or downstairs. Pressure at 1.5 bar. Whats goin on? 6 rads in total in house.
Old Aug 21, 2004 | 05:20 PM
SPADGE's Avatar
SPADGE
Have you lit the pilot
Old Aug 21, 2004 | 05:23 PM
The Sludge's Avatar
The Sludge
garibaldi
yes Spadge, it lights up when water heating up
jonseyrs's Avatar
jonseyrs
Default boiler
Does the main burner come on at all when heating is on?
Old Aug 21, 2004 | 05:25 PM
The Sludge's Avatar
The Sludge
garibaldi
when run hot water you hear it flame up, so to speak and the same if ay you turn up the water dial to a higher temp. Orange light comes on.
It doesnt howver come on when heating turned on
Old Aug 21, 2004 | 05:26 PM
SeanT's Avatar
SeanT
Combi
Could be anything!
What tests have you done?
Water heating works then?
Old Aug 21, 2004 | 05:27 PM
The Sludge's Avatar
The Sludge
garibaldi
no tests, cos i aint got a clue lol. water heating is sound, no problems
Old Aug 21, 2004 | 05:30 PM
The DIVA's Avatar
The DIVA
Have you got a roomstat and is it working(you can usually hear them click when you turn them)
Old Aug 21, 2004 | 05:32 PM
The Sludge's Avatar
The Sludge
garibaldi
no room stat mate
Old Aug 21, 2004 | 05:34 PM
SeanT's Avatar
SeanT
any pipes or anything at all on the heating side getting warm?
If nothing at all, and no room stat, then either control gear or the motorised valve for the heating side. Does anything click or whirr when you switch the heating on and off?
jonseyrs's Avatar
jonseyrs
Default boiler
Sounds like diverter valve on boiler, dont quote me on that though. On a combi the diverter valve can sieze up cos it made up of a brass valve with a diapraghm(large rubber washer) inside and these tend to become brittle and sieze up. The preset postion its in is for hot water, so thats why your hot water works. Combis are a nightmare, I just fit them, dont repair them yet so it could possibly be something else.
Old Aug 21, 2004 | 05:35 PM
The DIVA's Avatar
The DIVA
ave you tried the heating control dial on the vaillant in case its got a bad segment ?
Old Aug 21, 2004 | 05:36 PM
The DIVA's Avatar
The DIVA
if the burner aint chiming up when you put the heating on its almost certainly an electronic prob
Old Aug 21, 2004 | 05:38 PM
The Sludge's Avatar
The Sludge
garibaldi
Cheers Jonsey! What you reckon that will cost
Nightdavva, turned it up and down, but nothing matey.
Old Aug 21, 2004 | 05:47 PM
jonseyrs's Avatar
jonseyrs
If it is that? a diaphragm only costs a few quid then about 60 odd quid for the engineer to fit it. The shell of the diverter valve (the brass part) should be fine as the boiler is only 3 years old. They could turn up and it be somethimg else, but diaphragm sounds like most likely cause. By the way the pump does come on when heating is turned on doesnt it? does not make any strange noises?
Old Aug 21, 2004 | 05:56 PM
The Sludge's Avatar
The Sludge
garibaldi
well, when its turned on it tries to start, a bit like a car , but doesnt if that makes sense. It does it 3 or 4 times but then nothing
Old Aug 21, 2004 | 06:02 PM
jonseyrs's Avatar
jonseyrs
Feel the central heating pipes a couple of metres from boiler and you will feel water flowing through, then pump is fine.
Old Aug 21, 2004 | 06:03 PM
The Sludge's Avatar
The Sludge
garibaldi
ok. will do this tomorrow when i return from rsoc. I am just on way out now. Thanks for all your help guys. let you know tomorrow
Old Aug 21, 2004 | 09:49 PM
4x4pete's Avatar
4x4pete
Give me a call i will sort it si 07786 980 249
Old Aug 26, 2004 | 06:40 AM
The Sludge's Avatar
The Sludge
garibaldi
the boiler has now gone even madder. When you turn the heating off and turn to heat the water, the heating comes on and we get no hot water. Turn it the other way then we get water but no heating when the heating is supposed to be on.
The heating aslo does not come on with the set time on boiler. I came back from Donny on sundat to find the whole house at 83c!!!!!!!
gcfcos
59
Oct 6, 2015 05:04 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
cossie09
Sep 10, 2015 06:56 PM
