probable a silly question.
Old Aug 21, 2004 | 04:42 PM
kevandalice's Avatar
kevandalice
Default probable a silly question.
my gas central heating and hot water (pressurised cylinder type) are controlled by the same control box thingy. at the mo the c/h is turned off but when the hot water comes on, the boiler fires up.
should it do this?
Old Aug 21, 2004 | 04:44 PM
SPADGE's Avatar
SPADGE
Yep thats how it heats the water lol
Old Aug 21, 2004 | 04:45 PM
kevandalice
so whats the massive cylinder for in my cupboard upstairs??!! i thought that was what heated the water
Old Aug 21, 2004 | 04:48 PM
SPADGE's Avatar
SPADGE
Thats for holding the water or for heating it if you are using the immersion heater which is electric and independant from the central heating!
If the heating control is set to water then as soon as it needs to the boiler will fire up to heat the water!
Old Aug 21, 2004 | 05:07 PM
kevandalice
ok i'll get me coat
cheers spadge
turbotrev
39
Apr 17, 2016 09:03 PM
Rod-Tarry
75
Oct 13, 2015 04:44 PM
A.t.p
Sep 29, 2015 05:04 PM
SMILER258
Sep 28, 2015 09:04 AM
