Rebuild
Old Sep 4, 2006 | 01:54 PM
Cossy Chris's Avatar
Cossy Chris
Default Rebuild
Just enquiring at the miniute, im thing of rebuilding my cosworth engine. Its a 205 block what are the best pistons to go for and what compression is the best as I want it quite powerful. Thinking of going to a stage3. Any help would be great.
Old Sep 4, 2006 | 02:00 PM
For stage 3, a set of standard 4wd pistons (in .5mm oversize or whatever is approriate to the state of your block) would make good sense, as this will drop the CR a touch when used with the 2wd head.
I wouldnt go any lower than that unless you want to be making 400bhp+ though personally.
Old Sep 4, 2006 | 02:20 PM
SteveB's Avatar
SteveB
As above..... a nice stg 3 conversion imo is more than enough for use on the road...
Old Sep 4, 2006 | 02:40 PM
Cossy Chris
Is that all i need just standard 4wd ones. The car is a 2wd and the engine is pretty standard. What about conrods? I want it to be reliable and dont want it to blow up on me! lol.
Old Sep 4, 2006 | 02:42 PM
SteveB's Avatar
SteveB
Std 2wd engine is 8.0:1 compression ratio if you use 4x4 pistons it drops the ratio to 7.8:1..... and std rods are fine
bobsworth
77
Mar 24, 2016 09:30 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
Mc5506
Oct 5, 2015 09:57 PM
coscor86
Sep 20, 2015 01:21 PM
