some pics of the rs500
its now just how i wanted it to be really.its cost a lot more than i wanted to originally spend but its done now.
just been live mapped by kenny at motorsport developments and had coil pack conversion at same time and it really goes well now.
spec;
200 block,long studded,knife edged crank,uprated oil pump,low comp pocketed pistons,multi layer head gasket,ported head,bd14 cams,double valve springs,bronze guides,verniers.
850cc siemens injectors
t4 turbo with 360 bearing
l8 ecu
coil pack conersion
closed loop
air injectors
4 paddle clutch
mongoose exhaust
044 fuel pump
new fuel tank
gaz coilover kit,adjustable track control arms,polybushed
hi-spec 305mm front brake kit
raceline rl7's
secs monitor,aftermarket elliot 100mm rev counter,40psi boost gauge,oil press gauge,fuel press gauge.
peaks at 34 psi.
most stuff new or as new
most recent pics
spec;
l8 ecu
coil pack conersion
closed loop
air injectors
4 paddle clutch
mongoose exhaust
044 fuel pump
new fuel tank
raceline rl7's
peaks at 34 psi.
most recent pics
thanks for all the kind comments (except sticky).
its a mega car and i keep toying with selling it but really dont think i ever could.unless i was skint
-was toying with buying a new house but cant find one we like so looks like the rs500 is here to stay.
fast ford have been and done a feature on it recently so should be in the mag soon.
-was toying with buying a new house but cant find one we like so looks like the rs500 is here to stay.fast ford have been and done a feature on it recently so should be in the mag soon.
Originally Posted by staffi
Originally Posted by RS-Leigh
Looks good mate, love the wheels
Quite fancy a set for my 3dr..............
Leigh
Leigh
Am I not allowed to have a set of RL7's for normal use and then the split rims for the summer shows
Leigh
Originally Posted by fordsportjay
you do what you want mate-
: dont forget pete has gone over to the dark side
(where life is much more reliable
whats it like over there pete?
)whats it like over there pete?
Think he just misses his old cossie
Leigh
Who said anything about selling the BBS rims
Leigh
Im sure i no someone with a set of 18" RL7's for sale
Leigh
Leigh
[quote="RS-Leigh"]
Leigh
You tell him mate
Will give you a ring in a few months
RING ME cos ill probably have them on mine by then.(if ive still got it
Leigh
