Cosworth Saff 4x4 running in 2wd
Just discovered mt Saff 4x4 is only driving the front wheels or the rear wheels but not all 4. If I pullaway real quick I can spin the back wheels just like a 2wd. Have changed the oil in the transfer case but makes no difference. If I jack up the car on one side and turn the back wheel it does not turn the front wheel. If I try it on my buddies car the back wheel turns the front. Any ideas?
its more than likely that the center viscus coupling in your gearbox is shot.
this small unit is what transfers torque to the front wheels via a chain inside the gearbox and transferbox.it is the drive to the front wheels that will be lost,you will always have rearwheel drive
if this is the case i,m afraid its a box removal and coupling replacement,or a recon one from a specialist.
i have changed over the contents of a transfer box including the viscus coupling when the gearbox was totally removed which is mush easier,but it may be possible to do it in position, and if its proves a bit tricky then you have'nt much further to go to remove the box in total.
jason_nike
Aug 18, 2019 10:53 AM
Aug 14, 2015 07:29 AM
