cosworth probs
Old Sep 3, 2006 | 05:40 PM
cossie0_4's Avatar
cossie0_4
Default cosworth probs
i have a 2wd sapphire and it runs fine untill its warmed up to aprox 75degrees then its misfires and generally runs crap i have changed the blue sensor in the back of the head and also the brown 1 in the plenum but problem still there any help much appreciated cheers
Old Sep 5, 2006 | 10:01 AM
cossie0_4's Avatar
cossie0_4
took it out today and when its cold runs perfect still prob when warm any ideas cheers
Old Sep 5, 2006 | 10:36 AM
jon@work's Avatar
jon@work
tricky one this
have you checked the wiring to the water temp sensor ?
has the cam belt been off recently ?
Old Sep 5, 2006 | 04:29 PM
cossie0_4's Avatar
cossie0_4
i have had cambelt recently changed.
and the temperature gauge seems to work ok
do you repair cosworths for a living
Old Sep 5, 2006 | 05:00 PM
jon@work's Avatar
jon@work
could be worth checking that one of the cams isn't a tooth out
no - check the blue temp sensor wiring, not the temp sender (gauge) wiring
no thank fuck
When you say it runs OK until warm, do you mean it idles OK or does it actually drive OK.
Old Sep 5, 2006 | 08:12 PM
cossie0_4's Avatar
cossie0_4
car runs and idles ok and when engine is running and i disconnect the blue sensor plug it stalls does this info help cheers
Old Sep 5, 2006 | 08:13 PM
velocity's Avatar
velocity
try changing the coil, at least to eliminate it.they can break down when hot giving all sorts of problems,plug leads can do the same
Old Sep 5, 2006 | 09:00 PM
cossie0_4's Avatar
cossie0_4
tried changeing plugs leads and coil still problem there cheers
Old Sep 6, 2006 | 08:58 PM
cossie0_4's Avatar
cossie0_4
also fuel pressure reg cheers
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
28
Sep 8, 2015 07:10 PM
Adam Graham
Sep 6, 2015 06:04 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
