rs turbo gearboxes
Old Sep 3, 2006 | 05:12 PM
chelseabully1's Avatar
chelseabully1
Default rs turbo gearboxes
hello all just a quick question i was hoping someone could clear up
i have a s1 one and it needs a new gearbox its not completly gone yet but its hanging in there for dear life
i was hoping to get a box with a longer final drive some one told me the fiesta rs turbo has a longer final drive is this true and if so will it go stright on ?
as im fed up with doing 80 mph at 4000 rpm (or so) and with the cossie management on it its drinking juice no end on long runs
also i have heard that a diesel box from a mark 3 will go on
please help as i aint got a clue
cheers peeps
justin
Old Sep 3, 2006 | 05:16 PM
stuart collins's Avatar
stuart collins
ive got a stage 2 s1 box with a higher final drive in my s2 , give jamsport a ring will sort u out with 1
Old Sep 3, 2006 | 05:18 PM
chelseabully1
how much ruffly we looking at there mate
Old Sep 3, 2006 | 05:21 PM
chelseabully1
Old Sep 3, 2006 | 05:37 PM
stuart collins
give them a ring 2moro 01604 755529 and they will sort u a price out
Old Sep 3, 2006 | 06:08 PM
chelseabully1
cheers mate i will give them a ring
is it poss if someone could answer the original question please
Old Sep 3, 2006 | 06:10 PM
se mk3 cabbie's Avatar
se mk3 cabbie
mk5 1800 diesel box goes straight in mate, thats what i got, gearing much better
Old Sep 4, 2006 | 01:58 PM
stuart collins
550+vat stage 1 gearbox and wat eva final drive u want
Old Sep 4, 2006 | 03:35 PM
user 7082039239's Avatar
user 7082039239
Don't mention ze Vor
Will a MTX-75 gearbox from an early Zetec fit, too?
Old Sep 4, 2006 | 03:57 PM
addiction's Avatar
addiction
80 at 4000 rpm!!!
a diesel box does have a slightly longer 5th gear but is no stronger and does not have an LSD.
dont know about the gearing on FRST but also that has no LSD
Old Sep 4, 2006 | 03:58 PM
addiction's Avatar
addiction
O and both will fit straight on
Old Sep 4, 2006 | 05:14 PM
Oranoco's Avatar
Oranoco
I was under the impression that only a S1 casing could be used in a S1 due to the tie bar assembly.
My understanding is you can fit an S1 box to an S2 but not the other way round.
The myth surrounding the diesel box being tougher has been around for ages. It IS a myth though and the box is no tougher and has no LSD. The only thing in it's favour is it's cheap.
Bernie at CTS is the man who sorted my gearbox out and since fitting his box (my 13th) I've had no problems
www.gearboxman.co.uk
Old Sep 4, 2006 | 07:36 PM
stuart collins
s1 goes in to a s2 yes, but a s2 wont go in to a s1 with out using s2 anti rollbar and moddin the cross member
Old Sep 4, 2006 | 09:53 PM
notSteveS2's Avatar
notSteveS2
as above.... mk 3 boxes go into mk 4's.... bu tnot the other way round as mk4 uses cradle... mk3 does not...
Desiel boxes r shit!!! NO LSD... is crap in RST... i killed 1 and it was annoyin while drivin with n/s wheel always spinning!!!!!!!!!!!!
Old Sep 5, 2006 | 08:11 AM
JesseT's Avatar
JesseT
I have a Orion mk1 diesel box with S1 LSD and it's just brilliant. No tany stronger than a S1 box but much better ratios with a 3.58 final drive. The myth of the stronger diesel boxes is propably from the fact that never diesel gearboxes from mk5/6 escorts are stronger and they were used because they take the S2 8-bolt lsd directly.
SmudgerByName
52
Jul 28, 2016 06:14 PM
van_dogg_pavvy
Mar 3, 2016 09:30 AM
Matt Baxter
Sep 16, 2015 08:30 PM
mint_s2
Sep 2, 2015 08:58 AM
Cameron
14
Aug 9, 2015 06:28 AM
