Mk 5 escort cabriolet cossie rep - Fitting 4wd tunnel
Old Aug 20, 2004 | 09:52 PM
mk5_cossie_cab's Avatar
mk5_cossie_cab
Default Mk 5 escort cabriolet cossie rep - Fitting 4wd tunnel
Has anybody ever put a 4wd cossie tunnel in a mk5 escort cab.
I have managed to purchase a proper escort cosworth dash and centre console and at present trying to make it all fit the tunnel itself isnt a problem but having trouble with the gear stick and handbrake.
Any help would be greatly appreciated.
Old Aug 21, 2004 | 01:19 AM
luke89's Avatar
luke89
Team HOTHOT!
would u not have to take the hand brake out of the normal place and then just remount it to the tunnel ?? just a gess tho hope ya sort it
Old Aug 22, 2004 | 06:42 PM
RJS_SCORT's Avatar
RJS_SCORT
u need 2 move the gear stick extend ure gear linkages and re- mount the gear stick of course
Old Sep 4, 2004 | 11:55 PM
gavintwopies's Avatar
gavintwopies
well if you are going to put a tunnel in why not make some good use of it by putting a rwd set up in it ??
this will put the gear stick in the right pace for you at least
and is always a good fall back point the next time you visit your local friendly bank manager
"wey ye see mister, i got this tunnel that needs filling right..........................?"
Rs_Motion
Escort MK 5 / MK 6
43
Dec 27, 2018 11:49 AM
wheelwizardrefurbs
Aug 15, 2015 05:54 PM
Bloody-Fox
Aug 3, 2015 07:48 PM
3i Jim
Was It You?
Aug 1, 2015 06:33 PM
lockie
Jul 31, 2015 10:03 PM
