Overboosting
Old Sep 1, 2006 | 11:37 PM
KnoxyGtt's Avatar
KnoxyGtt
T34 just kicked in Yo
Default Overboosting
My car is badly over boosting, its really really enoying , ther seems to be a crap bleed valve coming from the turbo, ther is only one hose and a hold in the side of the bleed valve itslef, would i be just removing it, ill try and post a pic up later of it
Old Sep 2, 2006 | 03:44 PM
daveselwood's Avatar
daveselwood
can you post a picture of the set up
Old Sep 2, 2006 | 04:07 PM
jrs's Avatar
jrs
under bonnet bleed valve aren't that bad as long as there lockable just and easyer way to adjust the boost Do you have a boost gauge? I would play about the bleed valve to you get it right have it all the way in then just adjust the valve with a few turn's at one time. There should be one hose in the bleed vavle and one coming out
Old Sep 3, 2006 | 12:20 AM
KnoxyGtt's Avatar
KnoxyGtt
ill get a pic of it tomorow hopfully, thers only one hose coming from the bleedvalve, it looks like ther was ment to be another hose but ther just a hole in the side of it and u can see the needle itself, iv tryed turning it up and down, somthing i harly put my foot down overboosts, on the mottor way sitting at 70 ill just put the boot down a little and it dose it again, getting quite dangerous i think lol
Old Sep 4, 2006 | 10:59 PM
KnoxyGtt's Avatar
KnoxyGtt
the single hose that come from the bleed valve gose down to the turbo, probably the actuator im not sure didnt get a look, if i take it off and block up the hose its not running any boost at all
Old Sep 5, 2006 | 10:24 AM
stevos1's Avatar
stevos1
im not an expert but im prteey sure thats not right mate
Old Sep 5, 2006 | 01:21 PM
jrs's Avatar
jrs
It look's like your bleed vavle is fcuk there should be no hole look's like the side port has fallen off you need a new one there about £15
TIFF
Jan 1, 2006 10:15 AM
jonny gav
Ford Focus RS
Jun 8, 2005 11:27 AM
007
Nov 14, 2004 05:15 PM
TurboBlower
Oct 15, 2003 10:49 AM
