Injectors
theres a few you can use mate.
as long as they are the same ohm, and obviously the same injector, they will work.
iirc audi 2.2 injector are good for 250odd bhp
there also the delta intergrale injectors
Originally Posted by stevos1
i heard punto gt injectors are beige and the part numbers are indentical?????????
Bosch beige injectors or 703's are the correct injector to use iirc they are standard equipment in some BMW M3's. No point putting different ones in as if you don't have the chip to run them they will be useless.
They won't work properly with these ECU's as there aren't any off the shelf chips available to run different injectors. Your only option would be to have a chip custom written for your car but this is costly and very few people do this sort of work on Fieta RST management
cossie injectors may fit,but they will either melt the ecu.....or kill the injectors/engine etc etc. they are completly the wrong ohms
I CAN CONFIRM that the punto gt turbo injectors are exactly the same as the frst items............!!!
All stage 2 chips are written to run beige injectors
Bajoo can fit his spec injectors with ofab which will flow good for 330bhp on zetec turbos........so therefore be good enough to flow zetec,then it should be good enough for cvh!!!!!!!
My friend got a quote for around £900 for this. This included map sensor,Bayjoo spec injectors and a CUSTOM LIVE map from bayjoo !!!
no,the punto beiges are the same items as the fiesta beige items.
i think there are beige injectors in them horrible looking fiat coupe 20v turbo things too............
i got the t3 conversion with a chip and a uprated fuel pump if i got beiges does anybody think this will make a difference it wud set me back a fair bit fitted as well and the insurance company wants to know what my bhp would be any ideas anyone?
mk3ste
Oct 17, 2021 10:09 AM
DixieTheKid
11
Jun 6, 2020 11:20 AM
