Head gasket recommendation
Old Sep 1, 2006 | 10:45 AM
sandyRS16i's Avatar
sandyRS16i
Default Head gasket recommendation
Finally got my S2 RST engine rebuilt, had the car running and everything was fine until the head gasket went after about 30 miles . Got the gasket as part of a CVH gasket kit for an RST, although i'm now not sure that it was an RST kit . The car was running standard boost at 8 psi.
So can anyone recommend a cheap but good headgasket as i don't intend to trun the boost up above the 8psi as i am going to sell the car
cheers
Old Sep 1, 2006 | 10:52 AM
JesseT's Avatar
JesseT
Standard rst gasket is about the best. If you got a non-turbo cvh gasket, then the failure was expected.
Old Sep 1, 2006 | 10:57 AM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Standard ford gasket, their made by payen, and will take anything a CVH can throw at them! seen one with 28psi with no problem
It wasnt a felpro gasket you used was it?
Old Sep 1, 2006 | 11:17 AM
sandyRS16i's Avatar
sandyRS16i
cheers, guys.
No it was from a motor factors, think it was Motorcraft or Fram, deffo think it wasnt an RST item tho, went between pistons 2 and 3!!! at 8 psi!!!
Will get one form Ford then
Old Sep 1, 2006 | 11:47 AM
Rab's Avatar
Rab
Fucking superstar........
Standard Ford gasket all day long.
Old Sep 1, 2006 | 12:10 PM
Oranoco's Avatar
Oranoco
As above, I really can't rate the Ford item highly enough. My Felpro went between 3 and 4 mid race with a Porsche Was repaired with a genuine Ford item within a couple of hours but I couldn't find the Porka for a rematch
Old Sep 1, 2006 | 12:50 PM
Taylor's Avatar
Taylor
Hell yeah,can't go wrong there!
Old Sep 1, 2006 | 01:03 PM
alo's Avatar
alo
Do you know why the gasket failed in the first place?If you can, give the head a check for flatness, it might be warped?
Old Sep 1, 2006 | 01:04 PM
sandyRS16i's Avatar
sandyRS16i
cheeRS guys
gonna phone those pesky ford chaps later on
Old Sep 1, 2006 | 01:06 PM
Wazzzer's Avatar
Wazzzer
I've never had a problem with Felpro ones
Old Sep 1, 2006 | 02:12 PM
addiction's Avatar
addiction
genuine Ford gasket everytime
Old Sep 1, 2006 | 11:20 PM
stuart collins's Avatar
stuart collins
i ve run 2.24 bar on a standard ford gasket no problems
Old Sep 2, 2006 | 12:41 AM
vroooom ptssssh
It Wasnt Me!
Wes RS, Call it luck. . serious luck. . or change it before it gives up
Indyrs
Dec 4, 2022 12:39 PM
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
Fiddy
21
Sep 29, 2015 06:10 PM
pie-face
Sep 15, 2015 10:43 AM
