just finished and bored
Just spent approx 16k buiding my 3dr and im bored already, huge spec list im thinking ill let it go for £8.5k, seems pretty good i would of thought.Brand new longstudded 200 block with all machinig for take offs, 4stage dry sump system, mountune spray jets, lightened balanced bottom end (all standard size, cosworth pistons, rs500 head fully worked, new bd16,s wrc pulley, gt32 turbo, dizzyless, P8,New Quaife box, all custom built tanks, £2k aeroquip, ap 4paddle, 330 discs front, new rear discs and calipers,, new 6 point harnesses, two cobra seats on side rails, motorsport pedal box with remotes, custom heater and fan, power steering rad, all alloy rad and new pace 60mm intercooler, coilovers, adjustable top mpounts and tca.s. All ford racing gauges x5 fully built dash with ecu in glovebox,remote oil housing and cooler, swedish plenum,all lines inside, fuel cell in car with dry sump tank, red top battery in alloy frame, all polycarbonate windows, fuel filler in rear quarter window, 6point cage with diagonals and side bars, fully plumbed in fire extinguisher, lifter pump and 044 all built in car, all arches radiused under arches, 9x18 diablos on 15et, rs500 rear spoilers, quick release front bumper and loads more. not a forsale addy just want to know if the price is about right, regards Tony
as said, take most of the uprated parts off and replace with standard. If possible? or has is it too far gone as a track car to turn it back to a road car?
you will see a much higer return.
Originally Posted by Genesis Engineering
Return it to near as standard as possible and sell the uprated parts of seperately, chances are you'll get the best part of £8.5k for the near standard car + the extra cash for the uprated parts.
You'd be mad to sell it as it is now IMO.
Edit* just seen it. Cool car
Great spec apart What Quaife gearbox is in it?
Would make a GREAT track toy. Someone should but your arm off for that money!
Its built as a serious drift car, IIRC it has bigtime mods to increase steering angle and a decent diff too.
But like any serious drift car, the spec is about the same as a serious track car too, so can be used either way.
Bargain IMO.
aint that the drift spec one? if your bored of it tuck it away for a month and forget about it,
then go back to it have fun and see how u feel
no point breaking it, i rekon if you put it back to standard and sell the modded parts
Ultimate sleeper i think you're probably right, im gonna book it in tomorrow to be mapped properly and see what happens!!
Stavros, you'll love the new wheels on then 11x17 split rim compomotives with black 5 spoke centres and deep polished lip!!! they're mental, yup 11's will take pics of them tomorrow, guess i like building them rather than driving them,
IF the mods read the last line it SAYS do you think its worth £8.5k, im bright enough to put it in the for sale section if id put,FOR SALE on it, the worst id put on the original addy was i think i'd let it go for £8.5k and do you think its worth that!!! That in my opinion is for general discussion
