quick rack escort cossy & parts
Old Aug 31, 2006 | 01:55 PM
ATM SPORT's Avatar
ATM SPORT
Default quick rack escort cossy & parts
for sale
a quick rack 1.7 turns ,, but to fit std pipes and pump,, a direct replacment to std rack,, 500 pounds
Escort Cosworth Gearbox /Parts
Fix it big tooth GPN box new £3,250.00
Fix it big tooth kit complete £ 2650
Quaife 5 speed dog like new complete £ 3000
Complete new gear set 7 speed FF box£1500.00
Twin paddle clutch complete £200.00
GPN Centre VC pumped up exchange £350.00
Diff ‘s
9” CWP 4.6 NEW £300.00
9” FF Ricardo rear diff £2,950.00
6 ½” Plated front diff £750.00
Front diff strengthening plate Kit£65.00
7” plated rear diff complete £650.00
909 thick wall front diff £500.00
MANY OSBOURNE BIG TOOTH GEARS HELD IN STOCK
WRC / GPA Parts
New WRC IHI turbo complete £ POA
LHD GPA rack used £700.00
4WD mountune big wing sump £280.00
Mag 71/2 GPA sump complete £ 650
Single paddle GPN clutch used £180.00
New LHD GPA Clutch cable £50.00
New RHD GPA Clutch cable £65.00
Escort full length sump guard £250.00
Tarmac carbon sump guard ( needs repair ) £ 150
Pair alloy front uprights complete £1,050.00
Pair alloy TCA £500.00
Alloy front GPA top mounts a pair £200.00
9” Kevlar rear diff guard £75.00
Pair adj comp struts complete £300.00
.63 Turbo housing £150.00
GPA Square rear beam £450.00
Steel front GPA cross member £400.00
New GPA turbo with 247 £1,650.00
GPA / WRC lightened fly wheel from £150.00
Alloy toe links £300.00
Pair 380mm x 34mm discs £200.00
Pair Gravel mag rear arms complete £1,400.00
GPA rear stub shaft £ 150
GPA rear flange £ 150
New 14mm steel wheel nut set £ 60
Pair 50mm GPA bilstien damper with roller bearing spring seats £ 900
P8 ECU with ALS £750.00
WRC carbon clutch ( like new ) £ 900
Complete 315mm AP brake kit £750.00
Clubman rear beam with rose jointed rear arms £800.00
Full set WRC Reiger dampers complete £ 2500
Pair WRC front top mounts £ 500
Pair GPA front top mounts £ 300
Pair rear GPA active dampers complete ( dash adjustable) £800.00
Wide track front shafts complete £250.00
Alloy header tanks £45.00
909 alloy gear box mount £150.00
Alloy 909 rear diff mount £100.00
909 steering arms £200.00
Pair Rose jointed TRE and drums £350.00
New 8 injector WRC inlet manifolds complete £480.00
New Pectel 8 injector looms £545.00
New weld on chassis engine mounts £450.00
Weld on rear roll bar mounts £195.00
Kevlar inner wheel arches £ 200 a pair
Mag arm plastic protectors £ 250 a pair
Toe link plastic protectors £ 150 a pair
909 mud flaps £100 a set
ENGINES
WRC engine tommy field spec, WRC 200 block , accralite pocketed pistons, BD 15 cams, WRC polished & ported head, 8 injection inlet manifold, ALS spec, newly rebuilt never run, £ 8500
Wheels & tyres
7 x 15”raceline GPA 4 X 4 gravel wheels each £55.00
6.5 X 15” mag escort FWD RS2000 wheels each £55.00
8 x 16” OZ wheels GPA each £65.00
7 x 16” speed line wheels GPA each £65.00
8 x 16” original RS200 wheels each £150.00
Old Aug 31, 2006 | 08:52 PM
cressy's Avatar
cressy
has some one sent you my christmas list pal theres some nice goodies on there
Old Sep 1, 2006 | 03:28 PM
ATM SPORT's Avatar
ATM SPORT
hi
we always have this kind of stuff in stock
Billy_RS
16
Oct 11, 2025 09:41 PM
Rs_Motion
Escort MK 5 / MK 6
43
Dec 27, 2018 11:49 AM
Vincereese
Aug 18, 2015 03:57 PM
Gadget
Ford Escort RS Cosworth
Aug 13, 2015 06:43 AM
stickyslick
14
Aug 10, 2015 06:27 PM
