Upgrading fiesta rs fuel pump?
Took the car to the rolling road only to be told "we wont do it becoz it has a fuelling prob"
Apparantly the t3 converted chipped up fiesta of mine on the standard fuel pump doesnt supply enuff fuel/pressure and can cause detonation?
Is this tru do i really need a escort cossie pump or an upgraded one to save my car?
What injectors are you using and what Psi are you running? If you got beige injectors then a Escort Cossie one will be a good idea.
But a fueling problem doesn't mean it's the fuel pump, other factors to consider
Originally Posted by beef2001
im running a bar of boost and normal injectors i think, the rolling rd guys told me theres a fuelling prob and getting a cossie pump or uprated pump is what i need
Cossie pump isn't essential with 195 but it is advisable. I'm running mine on th estock pump with beiges, 195 and T3 but the car isn't used very often and a pump is on the shopping list
yeh i spose u cud be right i get a massive boost at 15psi then it drops off slightly, but if i got beiges and got them put in it wud mena another visit to the rolling road centre and its 150 quid a visit !! wouldnt it?
I went for an uprated fiesta pump coz its a straight swap and handles up to 300 bhp it was 100 with postage
the cossie ones are about the same give or take a fiver but its from the shop on ebay and hey are brand new
u can find second hand ones but if they fail its a big problem so I recommend new ones here save yourself a lot of problems.
BeEf.
T3 Hybrid
Chip
lowered
6 spoke dj alloys
respray
fuel area repaired
chrome underbonnet
in car adjustable boost controller
lockwood white dial dash and much more
BeEf.
T3 Hybrid
Chip
lowered
6 spoke dj alloys
respray
fuel area repaired
chrome underbonnet
you will need an escort cozzy pump and some bigger injectors to let more fuel in either beige injectors or greens a good tuner will advise you ,give pj motorsport a ring they are helpful
Originally Posted by Oranoco
044 pump. It's exactly the same part number be it classed as Escort Cossie or FRST upgrade pump.
Anyway, where in sunny North Wales are you??
Originally Posted by daveselwood
im in conwy.my mate has just put greens on his with a live mapped chip and a hybrid
i double checked the colour of the injectors and they are light green,hes also got a 3 bar map sensor of a cossie.hes had the chip written for him to go with a cam and a t3 but hes limited the boost to 12 psi untill he gets a big intercooler
does adding beige injectors really make a noticeable difference? i just received the upgrade fuel pump aint got round to fitting it yet any1 know if i will notice the difference., t3 and chip
wanna upgrade me fuel pump as well..can i use the upgraded cossie/fiesta turbo one?am running a 2l zetec on gsxr tbs.
am using st170 injectors?do i need to change em?
thanx
thanx
kosienutter
31
Aug 22, 2015 09:55 AM
