wirerringed block
Old Aug 28, 2006 | 11:24 AM
wimble's Avatar
wimble
Default wirerringed block
i am in the proces of rebuilding my engine and my block has got wire rings in it so what head gasket should i use ore should i take the wire rings out
Old Aug 28, 2006 | 11:47 AM
DENNIS's Avatar
DENNIS
sounds like you have got a wire rung block ( leave them in and use a group A gasket or similar ) or if the rings are cut through to the bore ( prob about 6-8 mm thick ) then its a coppers rings ( you will have to fit the same...
i have got a wire rung block on my car with a cometic gasket ( 30psi 450 bhp ) and has been as good as gold.....
Old Aug 30, 2006 | 03:02 PM
wimble's Avatar
wimble
chears mate i will get a group a gasket then
gcfcos
59
Oct 6, 2015 05:04 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
AJC
Oct 1, 2015 06:47 PM
20/20 vision
Sep 29, 2015 11:27 AM
20/20 vision
Sep 28, 2015 03:03 PM
