engine swap in a 3dr cossie and a 4x4 saph
Old Aug 27, 2006 | 06:30 AM
kiwicossie's Avatar
kiwicossie
Default engine swap in a 3dr cossie and a 4x4 saph
4x4 manifold on 4x4 engine in 4x4 car. exhaust fits.
3dr manifold on 3dr engine in 3dr car. exhaust fits.
3dr manifold on 4x4 engine in 3dr car. Will exhaust fit without mods to downpipe?
4x4 manifold on 3dr engine in 4x4 car. Will exhaust fit without mods to downpipe?
Am trying to work out if it is worth changing the manifolds over or just leave things as they are and mod the exhaust to make things work.
Anyone know if the turbos locate the exhaust in the same place.
They look like they're in the same place but would like to know for sure.
Brendon
Old Aug 27, 2006 | 10:14 AM
jon@work's Avatar
jon@work
there is no difference between the 3dr and the 4x4 engines (manifold fitting position wise)
the only differece is between the exhaust manifolds themselves - watch the exhaust on the anti roll bar, as, if I remember correctly, the turbo sits a little higher on the 4x4 manifold (but in the same place front-rear and side to side)
so if you've fitted a 4x4 manifold on a 3dr engine in a 4x4 car, then the exhaust will fit with the 4x4 manifold in a 4x4 car with either engine
Old Aug 27, 2006 | 10:59 AM
foreigneRS's Avatar
foreigneRS
Testing the future
as said, the 4x4 manifold will place the turbo outlet slightly higher.
i've fitted a 4x4 downpipe to a 2wd manifold and it sits very low to the road
Old Sep 22, 2006 | 05:17 AM
kiwicossie's Avatar
kiwicossie
Got it sorted.
Left the manifolds on their own engines and just added some tube to the downpipe on the 4x4 car.
Rebuilding the 3dr exhaust in 2.5" since the 3" is pretty drony between 2-3k.
Cheers for replies.
JoeyBoyden
Jan 4, 2024 02:36 PM
IAN RS2k
Aug 18, 2015 07:51 PM
Rickyrustyfox
Aug 13, 2015 01:11 PM
vdubo7
Aug 2, 2015 08:17 PM
Old ford
Jul 31, 2015 06:50 AM
