Piston question standard or low comp
Old Aug 24, 2006 | 07:38 PM
scotty86d's Avatar
scotty86d
Default Piston question standard or low comp
Mahle standard compression piston set. 285. Mahle low comp piston set 425. why should I spend the extra. getting them skimmed is a whole lot cheaper, but my question is are the low comp pistons stronger does anyone know?????thanks
Old Aug 24, 2006 | 08:28 PM
scotty86d's Avatar
scotty86d
anyone know guys, as im doing a cvh rebuild next week and want to know if i should fork out the extra or just stick with standard mahles(realistically what i can afford)
Old Aug 24, 2006 | 08:44 PM
xrchris's Avatar
xrchris
the way i see it is machining some of the piston away is sure to reduce its strength
Old Aug 24, 2006 | 08:46 PM
Rick's Avatar
Rick
Hi mate. I looked into this, and as far as i could work out - mahle do not do a low compression piston full stop. They are machined std ones.
Old Aug 24, 2006 | 08:58 PM
JesseT's Avatar
JesseT
Depends on boost level completely. For ~20psi and under the standard ones are better suited.
Old Aug 24, 2006 | 11:06 PM
scotty86d's Avatar
scotty86d
280 for the set of standard ones it is then. cheers guys.
James Porter
Oct 28, 2015 12:17 PM
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
blackbeautyzetec
Aug 29, 2015 02:11 PM
ekjim
Aug 17, 2015 08:57 PM
A.t.p
Aug 15, 2015 11:37 AM
