Car making a weird noise.
Old Aug 23, 2006 | 08:50 PM
Terry Tibbs's Avatar
Terry Tibbs
Default Car making a weird noise.
I seem to post a lot of problems up, but just as I want it minty mint. Car seems to make a whiney low rumble at 2k, never done it before, so thinking its the gearbox as the noise stops when u press the clutch. Any other ideas or is it a new gearbox time? if so Escort rs turbo ones go straight on yeah?
Old Aug 23, 2006 | 10:07 PM
fezzanut's Avatar
fezzanut
is it when your driving mate?could be a wheel bearing,yeah s2 gearbox will fit straight on tho id check your wheel bearings first
Old Aug 23, 2006 | 10:54 PM
Terry Tibbs
Nah I know the sound of one of them. its only when the car is in gear, around 1.8-2.3k
Old Aug 24, 2006 | 08:07 AM
SassyRS's Avatar
SassyRS
Little Miss...
Could be clutch release bearing???
Our old S2 used to do that.
If it goes when the clutch is pressed then its got to be gearbox/clutch really...
I'll ask Matt later see what he thinks
Old Aug 24, 2006 | 10:07 AM
BRAMMER's Avatar
BRAMMER
As sassy says if the noise goes if the clutch is pressed in then this diffinatly the clutch release bearing, so you May as well go fora paddle clutch and S2 box whilst you in there.
Old Aug 24, 2006 | 06:54 PM
Terry Tibbs
Didn't think it would be the gearbox really, the gears still pull fine.
Its got a paddle clutch at the moment.
Old Aug 24, 2006 | 11:13 PM
fezzanut's Avatar
fezzanut
ap paddle clutch?if so i know they are commonly noisy due to the springs on them.mines noisy.phone cts and speak to bernie he will give u some advice hes good as gold
Old Aug 25, 2006 | 03:39 PM
jayRS's Avatar
jayRS
sound like a relise bearing but it could be a main shaft bearing, common prob tbh.
if it is your lucky, mine never gave any warning till it broke up on me and chewed the shit out of the main shaft.
still that was about 6 years ago now
Old Sep 2, 2006 | 04:06 PM
daveselwood's Avatar
daveselwood
either way the bov eill have to come out ,stick an lsd box out of a series 2 in,mine is great if you do change the drive shaft oils seals as they are only a couple of quid.mine leak and ive got to take safs out to replace them
Churtz
15
Aug 13, 2015 06:40 PM
track.focus'd
Aug 12, 2015 05:53 PM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 07:06 AM
muz
Aug 1, 2015 06:48 AM
