Worn turbo oil seals
I have a bad case of smokey overrun on a SAAB turbo (9-5), the turbo is about to come off as I believe the smoke on overrun could be due to worn oil seals on the turbo (amongst other more expensive things...
Once I have the turbo off, is it easy to check the seals for wear ? Or, should I just get it sent to a specialist to overhaul ?
I don't really want to waste money and time on postage, etc... if it turns out to be something else.
Thank you
)Once I have the turbo off, is it easy to check the seals for wear ? Or, should I just get it sent to a specialist to overhaul ?
Thank you
to be honest id say take it to specialist to have a look and see what they say
what colour is the smoke? normally if seals have gone in a turbo its white smoke, black smoke is overfuel and blue smoke your is its burning oil
hope that helps buddy
Thanks for the help, I am confused about the colours though
It comes out blue, deffo oil smoke, but, if the turbo's oil seals have gone, I can't see that creating white smoke... water generates white smoke
Or, have I got this completely the wrong way round
take the exhaust off where the turbine wheel is you will see if it wet with oil on the wheel [do this by starting the car for 1 min on tic over then turn off and check]
i'll put new seal's in for you and bearing's plus balance if yoyu like
Oct 9, 2015 07:38 PM
Matt Baxter
Sep 16, 2015 08:30 PM
st220kyle
16
Aug 14, 2015 06:13 AM
