BOOST + RPM
Aug 22, 2006 | 09:43 AM
BOOST + RPM
ANY BODY KNOW HOW MUCH BOOST +RPM, LIGHTENED + BALANCED BOTTOM WILL TAKE, STANDARD COMP WITH SHOT PEENED RODS
Aug 24, 2006 | 01:16 PM
no one knows
Aug 24, 2006 | 01:52 PM
tell me about it
Aug 24, 2006 | 02:13 PM
Jano oddkid does a lot of work on standard bottom ends, would be the bloke to look up.
Maximum i think would be around 270hp and 25psi, could be completely wrong though
Aug 26, 2006 | 08:31 PM
Years ago I used to run a bottom end the same spec but ran a 7.3:1 comp ratio, it ran at 23psi but was running out of fuel if you ran more boost.
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
Marino
Sep 12, 2015 11:10 AM
