first attempt opinions please
Old Aug 22, 2006 | 08:54 AM
rob.c's Avatar
rob.c
Default first attempt opinions please
Just after you opions please folks
just getting used on paint shop and the missus wants her car to look like this.
did i do good
standard
and after a bit of handy work
Thanks
Rob
Old Aug 22, 2006 | 09:42 AM
Hayxr's Avatar
Hayxr
looking good to be babes
Old Aug 22, 2006 | 09:44 AM
rob.c's Avatar
rob.c
i knew you would like it
Old Aug 22, 2006 | 09:46 AM
Bungle's Avatar
Bungle
Very nice and hayley im sure ba off here has a brand new set of those rims for sale
Old Aug 22, 2006 | 09:50 AM
rob.c's Avatar
rob.c
xr3i130 they are BA's rims so gunna give him a call and make arrangments etc
Old Aug 24, 2006 | 09:33 AM
CosRush's Avatar
CosRush
Default Re: first attempt opinions please
did i do good
Not bad....... But if you look at where you have added the wheels onto your missus car, you can see the area's that need some more attention. The lines dont follow that of the car.
Ive highlighted in green.
Look at both and im sure you'll see what I mean.
The only other thing i'd add is, if you look at the shadow on the wheel centre also highlighted in green, you have to watch for where the shadow would fall based on the lighting of the car, and also a slight pespective change can help with the visual alignment.
also pay attention to where you position the new rims on existing tyres so that they look central.
Hope that helps. Keep up the good work
And I hope you dont think im trying to put you down or anything, you asked for opinions so thats what ive given you. Some people get touchy when they ask for opinions then dont like what they hear
Old Aug 24, 2006 | 01:18 PM
rob.c's Avatar
rob.c
thanks for the imput fella much appriciated.
im still getting use to the lasso tool so i cheated on this one useing the polygon tool which gave me the angled lines.
as for the shading i havnt reallt got a clue but still getting used to the tools etc.
any help or advice you can share would be cool
cheers
rob
Old Aug 24, 2006 | 01:28 PM
CosRush's Avatar
CosRush
No problem fella
If you use the zoom function when you do it, you'll be able to use lots of little lines using polygonal rather than bigger ones when zoomed out.
Once you have used the lasso around the new rims to be added, you can then use the free rotate selection to turn the wheel to get shading correct etc.
Also in the same section is the distort, pespective options as well.
Hopefully the above will help.
Dont hesitate to ask if you want to know any more, If i can help I will
Old Aug 24, 2006 | 01:38 PM
rob.c's Avatar
rob.c
Fantastic mate ill give it a go
Old Aug 28, 2006 | 02:40 PM
Bullett's Avatar
Bullett
rob i think it looks absolutely shite!!
only joking dude.
looks good and if you follow cos rush's advise you will be shit hot like him!
and one day your sig may be as good as mine.
tankybaby66
Feb 6, 2016 02:24 PM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
little bram
Sep 21, 2015 02:50 PM
rog
Sep 4, 2015 07:24 AM
hopper350
Sep 4, 2015 12:53 AM
