What is this valve on my Series 1 please ?
Ok am just in the process of replugging up my S1 after an engine bay resto, and i have one valve i just cant find a connector / plug for....
At the rear of the inlet manifold, at the bottom beside the branches, there is a valve that threads in the manifold, there is a water pipe that goes onto either side of it....one from water pump and the other from the block i think...
There is also a grey plug on it, that looks like it SHOULD HAVE something plugged onto it, but am buggered if i can find a plug in the loom anywhere that goes into it ?!
Can anyone shed any light please ??
Cheers in advance
Michael
Cheers in advance
Michael
Ive got this on mine, it has got a round shaped connector going to it, like the one that goes on the air charge temp sensor.On a previous engine change i had one of these that just had a stragiht through pipe with no connector so i dont think its a must for some ecu's? Mines a S2 but maybe this wasn't on the S1 if you have changed the inlet manifold aswell have a look on your old one c whats on that one.
Kiran1600E
11
Oct 2, 2015 11:35 AM
muz
Sep 30, 2015 08:29 AM
SMILER258
Sep 28, 2015 09:04 AM
