2wd saph cos idle and low rev issues
Old Aug 20, 2006 | 06:12 PM
john_p_b's Avatar
john_p_b
Default 2wd saph cos idle and low rev issues
here goes.........
car idles really badly. hunts between 400rpm and 1200rpm and at times just cuts out. if i put the lightest of light pressure on the throttle pedal then it sits at a steady 900rpm, as soon as i come off the pedal though it's hunting again.
also noticed tonight as i was putting it back in the garage it's got a slight missfire at low revs, smooths out at roughly 2k and when it's under load it seems to be fine. pulled like a train on the way back from donnington so i can't see it being anything terminal. hasnt had a set of plugs for 18 months so should that be the place to start?
thanks
john
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
FlashRS
13
Aug 31, 2015 06:02 PM
Anutternutter
Aug 21, 2015 06:07 PM
JoeyBoyden
Aug 18, 2015 05:56 PM
ray barker
Aug 7, 2015 09:00 AM
