3dr cossie brking pad warning light
Old Oct 1, 2003 | 06:45 PM
3dr cossie's Avatar
3dr cossie
Default 3dr cossie brking pad warning light
i have a 3dr cossie and the brake pad warning light flashes on start up. i thought it was being caused by a broken wire on one of the brake pads so i replaced it, but the problem still exists. does anyone know what else could be causing the fault.
p.s. i've just fitted new pads, but the problem was there before.
cheers
Old Oct 2, 2003 | 04:50 PM
Doug's Avatar
Doug
3dr try checking your brake fluid level if ok diconnect the level low ind plug an see
if it goes out usually a faulty sensor on the resovouir will bring the light on good luck
Old Oct 2, 2003 | 05:01 PM
3dr cossie's Avatar
3dr cossie
cheers i'll give it a try
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
dojj
15
Aug 18, 2015 08:21 PM
ar4ibaldo
Ford Focus ST
Aug 18, 2015 04:24 PM
Neatrags
Aug 16, 2015 07:57 PM
martynhomer01
16
Aug 4, 2015 09:55 PM
