p reg escort si cutting out
Old Aug 18, 2006 | 12:22 PM
Default p reg escort si cutting out
This question is for a mate of mine. He has a p reg escort si 1.8 estate , everytime he stops at a junction his revs drop and his engine cuts out Any ideas of what this could be?
Any help would be greatly appreciated. I dont know if it has an idle control valave or not?
Old Aug 18, 2006 | 12:30 PM
SafeChav's Avatar
SafeChav
Could be the ISCV, its located on the inlet manifold underneath the throttle housing (I THINK), check for air leaks aswell, and loose/split/unconnected pipes
Old Aug 18, 2006 | 12:43 PM
cheers for that will give it a try, thanks again
Old Aug 18, 2006 | 01:52 PM
just had a look, looks a bit tight but i'll sort it, my girlfriends fiesta had the same fault, but that valve was on the front of the inlet manifold and was a lot easier to get at.
Had to get it off the ramp as the boss didnt look to happy! lol oh well f*ck em
Old Aug 18, 2006 | 02:54 PM
SafeChav's Avatar
SafeChav
Yeah they are in a right shit place to get to
Old Aug 18, 2006 | 04:41 PM
Turbo Pez's Avatar
Turbo Pez
Good fun changing these, you think thank fuck wen you get it off!!
Just wait to you go put the new 1 on
Remember to reset ecu after changing, i just disconnected my battery for a hour or so!!
Pez
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
lukeeboy149
Aug 22, 2015 04:29 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
