electrical or mechanical?
Old Aug 18, 2006 | 11:44 AM
Hank Moody's Avatar
Hank Moody
Default electrical or mechanical?
just rebuilt my s1 engine, went to start it and its not gettin any fuel, the pump is priming fine and the fuel is getting to the distributor unit but no further, done the usual checks undoing various banjos and checking the flap etc,
is it sumthin electrical or wot??
Old Aug 18, 2006 | 12:22 PM
SafeChav's Avatar
SafeChav
Have you played with the mixture screw on the metering head at all?
And when you crank it over, does the flap bob up and down?
Old Aug 18, 2006 | 03:19 PM
Hank Moody's Avatar
Hank Moody
havent touched the screw, the flap doesnt budge unless i push it down myself
Old Aug 18, 2006 | 03:26 PM
SafeChav's Avatar
SafeChav
You have an air leak
Old Aug 18, 2006 | 04:43 PM
Hank Moody's Avatar
Hank Moody
so what now???
Old Aug 18, 2006 | 04:56 PM
davsmith64's Avatar
davsmith64
check all pipes, turbo pipes, intercooler pipes, every boost hose mate..
Old Aug 19, 2006 | 12:39 PM
SafeChav's Avatar
SafeChav
The flap won't move up and down much, so it may not be easy to spot from inside the car when you're cranking.
Have a glamorous assistant help you
Old Aug 19, 2006 | 12:42 PM
Hank Moody's Avatar
Hank Moody
plenty of gimps around to help. i was reading a similar thread about the same prob fixed by jamsport so i have ideas now! all i need is a day off work!
Old Aug 19, 2006 | 12:43 PM
SafeChav's Avatar
SafeChav
Ahhh yes, thats a very usefull thread being as you have the same fault
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
stevecfrst1
Sep 30, 2015 05:18 AM
20/20 vision
Sep 29, 2015 11:27 AM
Kam B
Sep 24, 2015 10:40 AM
