S2 BRAKE SYSTEM
Old 17-08-2006, 08:19 PM
GAFFA
GAFFA's Avatar
Default S2 BRAKE SYSTEM
IVE PUT 2 NEW BRAKE PIPES ON THE REAR OF MY S2 AND A NEW MASTER CYLINDER BLED ALL THE BRAKE LINES NO AIR IN IT . AND STILL NO BRAKES WHEN YOU PRESS THE BRAKE PEDAL A BIT ITS OK ..... BUT FULLY PRESS THE PEDAL FUCK ALL CAN ANYBODY HELP ??????????
Old 17-08-2006, 08:24 PM
vroooom ptssssh
It Wasnt Me!
vroooom ptssssh's Avatar
Did you bleed it with the wheels on?
As if you bleed it with the wheels off and car in the air, something to do with the load sensors at the back making it not bleed properly, someone will explain more
Old 17-08-2006, 08:28 PM
GAFFA
GAFFA's Avatar
yes mate i know all about load sensors . I had the wheels still shit brakes
Old 18-08-2006, 10:33 AM
HORNETS7
HORNETS7's Avatar
might be best using a auto bleed kit like the ones u use off the spare wheel this helps push any air bubbles out!!!
it does take allot to move a big air lock!
Old 18-08-2006, 12:24 PM
SafeChav
SafeChav's Avatar
Are you running discs on the back or standard drums?
Old 18-08-2006, 04:54 PM
GAFFA
GAFFA's Avatar
Ive used the auto bleed kit with a spare wheel and its still the same And yes its got a rear disc conversion 4x4 saffy ones i think
Old 18-08-2006, 05:53 PM
16vzetec
16vzetec's Avatar
ive had masses of troubles with mine.
are they on upside down like mine are?
if the nipple points down then thats your problem.
the only cure is to take calipers off and bleed them the right way up then re fit them.
you will get quite a bit of air come out trust me!
Old 18-08-2006, 05:56 PM
GAFFA
GAFFA's Avatar
Is that the rear ones your on about rs2000mk5 ???
Old 18-08-2006, 06:00 PM
16vzetec
16vzetec's Avatar
yes mate, my sierra ones are fitted upside down and alot of them are
Old 18-08-2006, 06:08 PM
GAFFA
GAFFA's Avatar
cheers mate just gone outside n had a look and your right the nipples are at the bottom I'll take the calipers off tomorrow and have a go I'll let you know how I get on
Old 18-08-2006, 06:29 PM
16vzetec
16vzetec's Avatar
glad to help mate
Old 19-08-2006, 07:57 AM
HORNETS7
HORNETS7's Avatar
well there u go u missed the all important information!!!
the cossie calipers on the rear as said above have the nipple facing down wards!!!!
unbolt the caliper and just turn it round to the top whilst still on the disc then bleed it up like that !
u'll find that works for u straight away !
happy days !!!!!!!!
Old 19-08-2006, 12:49 PM
SafeChav
SafeChav's Avatar
This is such a nightmare problem i was tearing my hair out when i did mine, especially after spilling all the brake fluid over everything in the engine bay to change the master cylinder, only to have the same problem
Old 19-08-2006, 01:18 PM
HORNETS7
HORNETS7's Avatar
he never said he had cossie calipers though in the first post lol! or else it would have been a easy firtpost fix lol
Old 19-08-2006, 02:00 PM
GAFFA
GAFFA's Avatar
CHEERS rs2000mk5 its worked their mint again now
Old 19-08-2006, 04:45 PM
16vzetec
16vzetec's Avatar
glad to hear it.
do you get problems with the backs locking at all?
Old 19-08-2006, 05:05 PM
GAFFA
GAFFA's Avatar
NO THEIR FINE IVE HERD THAT SOME PEOPLES DO THOU
01-11-2015 06:53 PM
XR4
Ford XR Range
01-10-2015 12:46 PM
muzzman1
30-09-2015 08:59 PM
Sp3no
27-09-2015 07:23 PM
Quick Reply: S2 BRAKE SYSTEM
