Gauge Fitting
How do I fit an Oil Temperature Gauge to a Zetec? Where do I need the sender? I assume it needs attaching to the Sump somewhere.
Also, I am also going to fit a Oil Pressue Gauge, i was wondering if anyone knew of any senders that allow you to connect the standard oil pressure outlet to, aswell as an aftermarket one?
Should be the same as a cvh pretty much.
Burton Power do a threaded sump plug that you screw your temp sender in.
Pressure gauge will most likely need a T-piece onto the back of the block alowing you to keep you pressure switch aswell as add the sender for your gauge..
All available from burton power for no more than £5 each
Hope that helps
Hope that helps
gchristophi
Aug 31, 2015 10:36 PM
mrmann
Aug 20, 2015 11:24 PM
track.focus'd
Aug 12, 2015 05:53 PM
