speaker polarity
Old Aug 16, 2006 | 06:31 AM
THE RADMAN's Avatar
THE RADMAN
Default speaker polarity
how do you identify which speaker wires are which,i know you can use a battery across the ends of the wire and watch the cone move in or out but what means its + or -?
Old Aug 16, 2006 | 07:02 AM
Eagle's Avatar
Eagle
Super Moderator
plus moves out ... but personally i would not put a strong dc currrent accross the terminals .. can you not look at what wires are connected to the speakers .. normally the black trace or the raised rib on the side is negative ...
Old Aug 16, 2006 | 08:01 AM
RichardPON's Avatar
RichardPON
Small square battery across the wires will show which way the speaker moves........ Positive forwards etc
Old Aug 16, 2006 | 08:19 AM
spudmurphy's Avatar
spudmurphy
yeah you should be safe enough with a little 1.5v battery, not always necessary to find out what wire is pos and which is neg, as long as both speakers are the same ie you can wire a speaker up 'backwards' as long as both speakers (assuming you are fitting fronts OR rears) are wired up 'backwards'.
Old Aug 16, 2006 | 04:20 PM
THE RADMAN's Avatar
THE RADMAN
problem is all the speaker wires have been extended in to the boot for the amp so they are all identical and im not ripping all the interior out again,lol, ill try the battery trick
Old Aug 16, 2006 | 06:56 PM
James's Avatar
James
Interesting, i was told it didn't actually make any difference which connection was positive or negative?
I've wired a few speakers up like this with no obvious problems?
TrevCos
Alloy wheels and ICE for sale
Sep 13, 2015 02:12 PM
mayo rs
Ford Escort RS Cosworth
Sep 1, 2015 10:18 PM
cameron2
Aug 30, 2015 08:15 PM
borboyous
Aug 22, 2015 11:17 AM
