Twin piston dump valves
I think I know how they work, but it confuses me a little
Below the standard big piston is a smaller spring and a smaller piston.
I take it that the vacumn that sucks the big piston open at idle cant suck the smaller one open too, hence why it dont stall.
But why cant it? Secondary piston and spring are both far weaker than the main one.
Me mildly confused
Me mildly confused
Me mildly confused
Me mildly confused
Stong on TB side - Opens main piston.
Weak on IC side - small piston closes under weak spring pressure - blocks hole that would normally vent air.
WD
Its a mainly cossie forum, we all HATE dump valves, try asking on a scooby forum its probably the one thing they actually understand technically
My wastegate sounds well phat man init, WIKID
whats a wastegate?
i thought were on about dump valves
as people call chatter "wastegate chatter" even tho its owt to do with wastegates
whats a wastegate?
this is a wastegate
sridgett
Oct 1, 2015 07:30 PM
Steve Escos
Oct 1, 2015 06:57 AM
