Does any other ford use the same plug lead connector???
Old Aug 15, 2006 | 10:19 AM
CosRush's Avatar
CosRush
Default Does any other ford use the same plug lead connector???
***edited***
see last entry
I need to find either the terminal ends for the plug leads where they plug into the boot of failing that somebody who makes custom length leads..........
Can anybody help please???
Old Aug 15, 2006 | 10:24 AM
AlexD's Avatar
AlexD
Post Miester !
http://www.fuelcat.co.uk/formulaPower.html
These guys can make custom ones mate..
I have a race set on the sapph..
Al...
Old Aug 15, 2006 | 10:46 AM
scruffythefirst's Avatar
scruffythefirst
Vehicle wiring products do the connectors
Old Aug 15, 2006 | 10:52 AM
SapphyMike's Avatar
SapphyMike
Magnecor will make custom sets up.
Old Aug 15, 2006 | 11:03 AM
CosRush's Avatar
CosRush
Unfortunately they dont Hugh.......
They're 6.5mm ones as opposed to the 4mm ones on the standard leads.........
Old Aug 15, 2006 | 11:04 AM
CosRush's Avatar
CosRush
Thanks for the help though all of you
I can contact the above companies and see whats what......
cheers
Old Aug 15, 2006 | 12:36 PM
CosRush's Avatar
CosRush
Ok....slightly different angle on this...........
Is there any other Ford which uses the same plug lead connectors (long reach)???
or any other car that uses the same ones..........
Old Aug 15, 2006 | 12:51 PM
SapphyMike's Avatar
SapphyMike
Zetec's do dont they? just they they a coil pack end, rather than dizzy cap..
Old Aug 15, 2006 | 12:55 PM
CosRush's Avatar
CosRush
Are they the same then Mike??? length etc.........are they sealing as well??
Old Aug 15, 2006 | 12:58 PM
SapphyMike's Avatar
SapphyMike
i couldnt say mate - not really looked into a zetec / cossie lead in great detail..
Old Aug 15, 2006 | 12:59 PM
nomad's Avatar
nomad
no other ford use the same connector they were only fitted on the 16V cosworth engine, VW uses the same ends for their golf GTi (not sure if they still use them in the newer golfs tho). cheers nomad
Old Aug 15, 2006 | 01:02 PM
nomad's Avatar
nomad
saying that i would imagine that most ford leads are held on using the same crimped connector that you have in your picture, i am only guessing tho,might be worth getting a cheap ford lead and pulling it apart cheers nomad
Old Aug 15, 2006 | 01:17 PM
CosRush's Avatar
CosRush
Thats along the same lines as what I was thinking . adding the coilpack connectors is a piece of cake, but the spark plug connector is difficult since the connection is moulded within the connector about 1 inch in, hence the terminal connection.
Did BERU make all the leads for the Fords of that era do you know???
If nobody knows I guess i'll have to take a trip to the breakers
If so, then you've sussed it, as long as I can find a set of original leads, just unplug them and fit to my connectors ......
Old Aug 15, 2006 | 04:41 PM
the original's Avatar
the original
can you not remove those brass/copper connectors and crimp/solder them onto the end of any plug lead long enough?
Old Aug 15, 2006 | 04:43 PM
Billabong's Avatar
Billabong
If needed, I think Mike R can locate/supply you custom length leads.
Old Aug 15, 2006 | 04:53 PM
CosRush's Avatar
CosRush
Possibly, but they double crimped, and the main cripm to the core is obviously very small, I suspect prising it open will not leave it in a very good condtion for resealing...........
I found some new, but the bloke wants Ł2 for each terminal........
and Ł6 for postage......from Cornwall
Old Aug 15, 2006 | 04:56 PM
CosRush's Avatar
CosRush
Thanks Bill,
I can make the leads myself no problems, but wanted to keep the original BERU plug connectors since they have the resistor internally (unlike the cheap all rubber replacements).
But because of this I also need the BERU terminals they use to connect the spark plug and dizzy ends to the lead..........
Hence why I thought anybody out there who makes custom leads may well have some of these terminals......
Old Aug 15, 2006 | 05:56 PM
Billabong's Avatar
Billabong
Ah, sorry, it appears I didn't read the post properly.
j.hammond1
30
Oct 31, 2021 05:28 PM
borboyous
Aug 22, 2015 11:17 AM
Anutternutter
Aug 21, 2015 06:07 PM
Zoggon
Aug 10, 2015 10:39 AM
