Any Excel guru's around
I need to set up a spread sheet to help with a quarterly rebate claim (from shipping lines).
I would like it to be done on Excel that way everyone & they're dog will be able to use it!
Now i've had a play but i'm fucked if i can work out how to get the B/L numbers to run numerical?!? Also i'd need Ecxel to pick out dates per quarter, thus allowing to collate the info.
Any tips?
In the past we would have a sheet for each carrier, for each routing but i can work out the coding for that..........
Screen dump of whats needed info wise.
Any tips?
email it to me at mattrs1600i@hotmail.com and i'll see what i can do buddy. Will later on this evening be ok?
if you highlight the values you want to run in order,and then click one of the icons above the F column in your pic,that should give you the option to order them how you want them...i think
If it is just a case of rearranging the rows so that they are in BL Number order, click DATA, SORT and select Column F from the pull downs. There is usually an icon on the toolbar but it isn't showing on your screen print but you can add the button.
Let me know if this isnt sorted and I will have someone look at here.
Add me on MSN or email to my MSN account.
BTW - Saw your post in the shipping one, do you work there or was it you who sorted it for me? Thought it was someone called Carl RST or similar. Good company either way
saff_cossie
Yes it was me
I've worked for Anglo for near on 9 years now, thanks for your kind words............It makes a change as usually all you hear about are the bad things
My user name back then was JayFRST..........but seeing as i grew up & brought a proper car i thought i'd change it!
saff_cossie
Yes it was me
I dont think I met you that day, Dan might have been the guy.
Yep eratic idle was fixed, dodgy old sensor and Mike R posted me a new one.
If you get any excel issues again, send them my way as my Project Manager is a whizz and can do far more than I even realised in Excel.
Cheers fella, gent.
And if you need any cossie parts sent give me a shout..............
My brother hopes to be on the way in the next 12 months so have sent him your way. Not sure if he is bringing a car or not but has a lot belongings.
