Clifford G5 Avantguard 5 fitting instructions
Old Aug 14, 2006 | 12:48 PM
manoj's Avatar
manoj
Default Clifford G5 Avantguard 5 fitting instructions
Does anyone know where I can get these or download them from..??
I would like to fit this Alarm myself if possible, the Alarm has already been removed professionally from an EsCos.
thanks,
Manoj
Old Aug 14, 2006 | 12:50 PM
It should be pretty much self explanatory assuming they have re-labelled all the wires thoroughly when they uninstalled it.
If they havent you are fucked and wont be able to!
Old Aug 14, 2006 | 12:55 PM
Dave Henshall's Avatar
Dave Henshall
owners guide
http://www.clifford.com/guides/ogs/G909640_4_03.pdf
fitting guide
used to be on the site, but is now gone
Old Aug 14, 2006 | 01:01 PM
manoj's Avatar
manoj
Originally Posted by Dave Henshall
owners guide
fitting guide
Hi Dave,
thanks mate, i did already download the Owners guide.. but as you said the installation instructions have been removed from the site.
Chip.. i'm fecked. or i'll have to get it pro fitted by Clifford dealer.
thanks,
Manoj
Old Aug 14, 2006 | 01:03 PM
A pro clifford installer wont be able to refit it unless you have labelled the wires when you unfitted it.
Old Aug 14, 2006 | 01:38 PM
Stu @ BSC's Avatar
Stu @ BSC
No Need for the system to be labelled I can install it without.
Old Aug 14, 2006 | 01:51 PM
manoj's Avatar
manoj
Stu,
Fancy coming down to London to install it.. lol
I'll get it booked in with yourself as soon as the car is back on the road.. how much roughly for the installation..?
thanks,
Manoj
Old Aug 14, 2006 | 02:18 PM
DaveEscos's Avatar
DaveEscos
Chip is talking bollocks (again), you do not need everything labelled.
Manoj, Ill delve deeper for the fitting instructions, It was in a little white manual that came with the alarm.
did you get the valet switch, LED and fob ok?
Old Aug 14, 2006 | 02:25 PM
Stu @ BSC's Avatar
Stu @ BSC
Stu,
thanks,
Manoj
Lol, Yeh bit far for me I'll PM a Price to you.
Old Aug 14, 2006 | 02:34 PM
manoj's Avatar
manoj
Many thanks for the extra bits.. all received on Friday.
PlainView2 Valet Switch., Pre-Wired blue status LED., 2nd Clifford Key Fob, Owners Manual. AvantGuard 5
However, can you pm or email me..
your previous Valet Code..?
your previous Blackjack Code..?
also received a long wire with connector\mounting - what is this for..?
thanks,
Manoj
Old Aug 14, 2006 | 02:51 PM
Really?
Fuck knows how, lol
Certainly most installers wont then, but i stand corrected on the fact that some obvioulsy can
Although i guess if the wires always come out in the same place its possible to look at one that is labelled and compare?
Clifford technical support told me there was no way of idetifying the wires reliabley like that though (as you just have a pack of identical black wires that they reckon dont come out in the same place every time).
But thanks for correcting me if thats the case
Old Aug 16, 2006 | 01:21 AM
SS1's Avatar
SS1
strange isnt clifford black wired ..apart from the wire ends
if your a alarm tech.. you cut off the id tags when you connect them
or they where slip over tags pull off before connect ..but still number or colour coded ...
so i have been told ..old freind worked for lazerline ..Scorpion car alarms
basic merc car alarms back in the old days....
Old Aug 16, 2006 | 01:26 AM
Indeed, i fail to see how you can identify the wires again, unless its possible to tell by the resistance of them or similar?
Old Aug 16, 2006 | 09:23 AM
Stu @ BSC's Avatar
Stu @ BSC
I could tell you how its done, but then I would have to Kill you. Lol
Old Aug 16, 2006 | 09:29 AM
COMEDY DAN's Avatar
COMEDY DAN
No1 Blower.
He sure can
Old Aug 16, 2006 | 09:55 AM
Fair enough.
Nice to know that there is someone out there capable of undoing it when some numpty rips all the wires out without labelling it
Old Aug 16, 2006 | 02:26 PM
Dave Henshall
here you go,
the installer guide for the concept 600 (which form part of the avant guard)
you may need to resister on the site, but the downloads arefree:
intellistart, windows, voice etc
http://www.mkivsupra.net/vbb/forumdisplay.php?f=117
Old Aug 16, 2006 | 02:33 PM
here you go,
Thats no use to him without the wires labeled though, he will need to identify the wires before he can do anything with it
Plus isnt the avantgarde 5 based on the 650 which is totally different install to the 600, as one is a G5 and one is a G4 and there are quite a few changes?
Old Aug 16, 2006 | 02:34 PM
Dave Henshall
TRUE , TRUE -
BUT it still answers the tread topic...
Old Aug 16, 2006 | 02:52 PM
manoj's Avatar
manoj
here you go,
Dave,
thanks mate.. that helps even though the Avantguard 5 is different its still very usefull for smart windows, remote start etc..
cheers.
Manoj
Old Aug 16, 2006 | 03:26 PM
Stu @ BSC's Avatar
Stu @ BSC
here you go,
The G4 Clifford concept 600 was made at the Clifford factory And all G5 products are made at the Directed factory and yes all the wiring colours have been changed.
Old Aug 16, 2006 | 07:21 PM
Dave Henshall
bigryrs
Mar 28, 2016 09:11 PM
bigryrs
Fiesta RS1800/RS Turbo
14
Jan 21, 2016 09:54 PM
Daisychain
Aug 22, 2015 08:12 PM
Dr. Ickxs
Aug 15, 2015 11:34 AM
Davemurphy007
Motorcycle Chat & Sales
Aug 14, 2015 05:58 PM
