What to look for when checking for Play in a turbo
Old Aug 14, 2006 | 11:57 AM
Gra's Avatar
Gra
Default What to look for when checking for Play in a turbo
Gonna be checking the Turbo tonite on the cossie, just to see if there is any play in the shaft etc, i remeber being told when i was selling my old cossie T3 that there is always a bit of play, but other than that i cant remember which way there should be play etc, can someone tell me what to generally look for with regards to checking for Play in the shaft
Old Aug 14, 2006 | 11:59 AM
_DAN_'s Avatar
_DAN_
Yoon
Don't take me as gospel but isn't side to side play bad butend to end ok'ish?
Old Aug 14, 2006 | 12:00 PM
TIFF's Avatar
TIFF
Chasing Radders
If you can pull the shaft in and out slightly it is ok, but if it moves up and down then there is some play in it
Old Aug 14, 2006 | 12:16 PM
ballin's Avatar
ballin
there will always be some play as oil pressure sorts it out.
i actually thought in/out was bad and up/down a little was ok
Old Aug 14, 2006 | 12:35 PM
SapphyMike's Avatar
SapphyMike
ive had a brand new turbo have up and down / side to side and no front to back play..
Old Aug 14, 2006 | 12:42 PM
Stu.H's Avatar
Stu.H
No movement at all on my TT t3 stage 1
Old Aug 14, 2006 | 12:46 PM
Gra's Avatar
Gra
no i fookin confused
Old Aug 14, 2006 | 01:17 PM
xr4x4rs's Avatar
xr4x4rs
if you can pull it in and out then its on its way out
side to side up and down you will always have a bit of play
i even had it on my brand new t35 a few years ago
Old Aug 14, 2006 | 02:21 PM
Tarren's Avatar
Tarren
Totally Agree any movement .. in out its on its way out..
Every turbo i have had has a little side to side
Old Aug 14, 2006 | 02:29 PM
Diamonds.'s Avatar
Diamonds.
yeh i pooped my pants when i could move it side to side a bit on my new stg3 T3. but was told by a few thats fine as said above
but as far as i have been told in and out aint good
Old Aug 14, 2006 | 02:34 PM
Gra's Avatar
Gra
cool cheers peeps
Old Aug 14, 2006 | 06:59 PM
Gra's Avatar
Gra
ok, just checked the turbo, i can move it a bit up and down and a small bit left to right, but it doesnt move in and out at all, so alls good me thinks
Old Aug 14, 2006 | 07:15 PM
SteveB's Avatar
SteveB
Gra,
put the tools down and step away fom that vehicle........
and defo DO NOT ring Keith for any help whatso ever!!!!!
PS turbo sounds fine to me
Old Aug 14, 2006 | 07:17 PM
andre_k's Avatar
andre_k
Old Aug 14, 2006 | 07:30 PM
Gra's Avatar
Gra
Originally Posted by Steve_B
Gra,
had the cam cover offski, the ECU apart, this car deffo aint gonna start again Steve have a lookski at my chip post see if you recognise the chip please
Old Aug 14, 2006 | 07:34 PM
SteveB's Avatar
SteveB
OMG it'll never be the same again Mind you it could be worse...... Keith (took me 8 hrs to change discs and pads on a S2) could have been envolved so not alls lost just yet
TBH fook knows what the chip is
Old Aug 14, 2006 | 07:39 PM
AlexF's Avatar
AlexF
In and out is very bad news...
a good turbo will also have minimal movement left/right or up/down.
The reason for play is that the bearings float (hence the pressure oil feed) - and so without the pressure there is some movement.
By some I mean a TINY amount - a natscock - virtually fuck all!!!
Alex
Old Aug 14, 2006 | 07:44 PM
Gra's Avatar
Gra
cheers steve, i aint tht bad, changed all the suspesion on the rsturbo in just under 3hrswhich isnt bad for me lol
cheers alex, there isnt a lot of movement at all
Old Aug 14, 2006 | 07:45 PM
SteveB's Avatar
SteveB
Still using your littluns tool kit????
Matt Baxter
Sep 16, 2015 08:30 PM
dingla rs
Aug 24, 2015 11:52 AM
Danielbetty
Aug 23, 2015 12:52 PM
turbobill
Aug 9, 2015 05:21 PM
Tinshaw
Aug 4, 2015 09:16 PM
